Squires rear turbo system.
Originally Posted by apkano
The SRT engine swap into a manual trans limited has already been done....
https://www.crossfireforum.org/forum...dp+engine+swap
Originally Posted by robs 04 crossfire
yes we know it has been done we where talking about how much it would cost to do a srt swap..
You may not get an answer right away, Derek's a very busy person, but I'm more than sure he'd let you know how much he's already spent on the project.
BTW.......swapping out the trunk from a Limited and wiring up the neccessary controls for the spoiler is WAYYYY cheaper than trying to swap in a SRT engine or turbocharge a Limited.
Originally Posted by technojunky
true, but then you're driving an automatic instead of a manual, and you have a large fixed rear wing instead of a nifty little spoiler that pops up and down
I do not think the trunk was as much of a concern as the manual trans, I am not 100% but am assuming this would be quite an undertaking as well??
Can our manual trans handle 350-400 HP?
The problem with mixing and matching transmissions, manual for auto and vice versa, is that the PCM still looks for inputs from the transmission. You'd have to find a way to fake the computer into believing the same type of transmission is there. It's wired into the stability programming, security system, as well as the powertrain module. This was one of the big reasons HDDP went with the Bosch controller, you don't have to worry about that stuff anymore.
The flex-plate has a different bolt pattern than the flywheel where it mates up to the crankshaft.
A SRT swap is no problem if you take every last piece of the mechanical parts as well as every bit of electronics. After all, the body dimensions are the same SRT to non-SRT, but every single thing under the hood and how it operates is different.
As far as knowing if the manual trans is up to the power of the SRT engine....I have no idea. HDDP did it after a LOT of effort and money, but his is a track car, he expects things to break.
i think the most cost effective and easiest way to mod the car would be get the 3.8l short block with a 9:1 compression ratio that should do around 400 hp and then in the future once they have figured out the electronics about adding a piggy back or modding the stock ecu using the method recommended by Kanzus and then you should have around 500hp-550hp using a turbo or a blower. Of course along the way the transmission, suspensions, brakes, and other stuff will need to be replaced for added power and weight.
WAIT WAIT WAIT, hold the phone.
I think I'm gonna cry.
Did i just read somewhere that my manual trans wont bolt-up to the srt-6 engine?
I want to do a swap and put the srt-6 engine in my '04 limited. utilizing a piggy-back system from split second to account for added boost. (missing link)
But now i think i read that i cannot do this because the engine will not bolt-up to my manual trans, please someone tell me this is a bad dream.
Thanks,
Justin
Thanks,
Justin
Thanks,
Justin
Thanks,
Justin
Originally Posted by Forza1
You guys talking about the ECU realize that you could have an AEM stand alone ECU installed and tuned for less than $2k?
house of power used the split second piggy back system, on their MBZ project. slapping a supercharger on a N/A 430 V8.
their piggy back system is like $300 and that includes the software.
thanks,
Justin
thanks,
Justin
I spoke to Freddy at STS yesterday and he mentioned that there are two Crossfires running their system. One in south Carolina and one in Louisiana. Once the V8 is running, this may be a way to make it really scary. The sound of the turbo in the rear makes the car sound like a cross between a regular engine and a jet engine. Here is a link they sent me:
http://www.youtube.com/watch?v=JzUB95N4tDQ
I have a Greddy E-manage blue that I could use for this build, But i think I'm going to build slow. For now just port my intake, larger TB..etc. Just prep my motor to handle a turbo and make some power at the same time.
i do not like the idea of the turbo under the car in the rear for safety reasons what happens if i bottom out and hit a hole or something where the turbo will be located i am worried. what about relocating the battery to the rear and putting a turbo in that area or relocating the overflow tank and putting a turbo in that area. if we can just get a custom piggy back then i do not see the issue with just fabricating some piping and fitting a turbo. what is the highest pounds of boost we can run using the piggy back. i figure stock engine should do 8lbs-12lbs of boost and more if you get the forged internals.
[MEDIA]http://www.hopracing.com/gallery5/DSC00637.JPG[/MEDIA]
[MEDIA]http://www.hopracing.com/gallery5/DSC00639.JPG[/MEDIA]
[MEDIA]http://www.hopracing.com/gallery6/DSC01219.JPG[/MEDIA]
[MEDIA]http://www.hopracing.com/gallery6/DSC01218.JPG[/MEDIA]
It will bolt right up and has been done before by HDDP.
https://www.crossfireforum.org/forum...t+bolt+pattern
I don't know how he remedied the situation........but again I say the bolt pattern is different.
Originally Posted by newCrossfire
I believe HDDP just used a different flywheel from another MB vehicle and it bolted right up. as far as strength he just used a Spec stg 3 clutch.
