TVT300 Preview...
Old May 1, 2009 | 09:19 AM
  #61 (permalink)
TVT_DESIGN
Guest
Posts: n/a
Default Re: TVT300 Preview...
Hopefully very little. I was more excited to get the numbers then anyone on here.
Old May 2, 2009 | 01:16 PM
  #62 (permalink)
Sean760's Avatar
Will the test car be running one of the new Throttle Bodies?
Old May 3, 2009 | 01:50 AM
  #63 (permalink)
cmac's Avatar
I suppose I should start saving money so i can put this on my car! I have always told everyone that the 300rwhp range is what I'm shooting for. Doing it Na means no turbo lag or crazy SC set ups... Thanks TVT if it wasn't for you guys it might be looking bleak..
Old May 3, 2009 | 04:32 AM
  #64 (permalink)
stevieb's Avatar
Although I respect your optimism I really dont think we will ever see 300rwhp on a na Crossfire. Unless someone else wants to shut me up and tell me different
Old May 3, 2009 | 03:07 PM
  #65 (permalink)
X-FIREcmv's Avatar
def agree. i highly doubt anyone will be able to get that N/A. i think the highest we will ever see (due to TVT's amazing skills ) is around 260ish. im sure theyll get around there in the future. that would be AMAZING!!
Old May 4, 2009 | 01:34 PM
  #66 (permalink)
Sean760's Avatar
I think it's possible wether someone will do it, who knows. There are a few things on the motor that are really restrictive and no machine work has been done on the motor porting of the heads etc bigger valves cams all things that could possibly make more power. If your talking about adding bolt ons and just tune then 260 sounds about right.
Old May 4, 2009 | 01:40 PM
  #67 (permalink)
tom2112's Avatar
She can ride with me ;)
I think CMAC is confusing wheel hp with crank hp, that's all. 300 at the crank is very do-able with bolt ons and a tune. But like Sean760 says, though, anything is possible depending on how hard you want to work - porting, polishing, cams, etc. etc. etc.
Old May 4, 2009 | 01:50 PM
  #68 (permalink)
Stogey's Avatar
TVT how bout them dyno numbers ? Inquiring minds wanna know !!!
Old May 4, 2009 | 09:38 PM
  #69 (permalink)
robs 04 crossfire's Avatar
yeah even 260 rwhp is alot better then what we have now any power i can get i will go for
Old May 4, 2009 | 10:26 PM
  #70 (permalink)
Tazz's Avatar
I know it's dependent on the type/brand of dyno, but what's the usual rwhp number for the stock Xfire (215 hp rating at the crank?)?
Old May 5, 2009 | 01:03 AM
  #71 (permalink)
newCrossfire's Avatar
175 give or take.
Old May 5, 2009 | 04:32 PM
  #72 (permalink)
TVT_DESIGN
Guest
Posts: n/a
175 on a typical Dynojet. We saw 211-215 RWHP with our TVT265 kit on the same dyno. We're shooting for about 250 RWHP with our TVT300.
Old May 5, 2009 | 04:45 PM
  #73 (permalink)
amick6534's Avatar
TVT what is the rwhp on the SRT. Thanks!
Old May 5, 2009 | 05:12 PM
  #74 (permalink)
TVT_DESIGN
Guest
Posts: n/a
Usually around 275-285 stock, depending on dyno.
We had a modded (pulley, tune, intake) on the dyno we will be using for our final test and it put down 290 RWHP. A stock Crossfire put down 158 RWHP on this dyno.
Old May 5, 2009 | 07:23 PM
  #75 (permalink)
copycat's Avatar
Well....if you get 250 to the rear wheels, sign me up.
Old May 5, 2009 | 09:59 PM
  #76 (permalink)
JimmySkullz's Avatar
250 RWHP would be sweet!!
Old May 6, 2009 | 07:42 AM
  #77 (permalink)
yeah i would be more then happy with 250 i mean as long as its not crazy expensive, you know but that almost 100 rwhp
Old May 6, 2009 | 08:10 AM
  #78 (permalink)
Originally Posted by TVT_DESIGN
Dyno coming tomorrow...
Anything yet? That was the 28th and we are still anxiously awaiting....
Old May 6, 2009 | 10:31 AM
  #79 (permalink)
TVT_DESIGN
Guest
Posts: n/a
I have to coordinate with LET and the dyno owner to get this to work. It just happened that they were in NJ at the time and it would've been perfect.
Old May 6, 2009 | 04:12 PM
  #80 (permalink)
so how much longer you think it will be before you get the dyno?
