Kaboom
Old Oct 28, 2015 | 09:21 PM
trocar's Avatar
Default Re: Kaboom
Originally Posted by pioneer4x4
Looks like there are tons of used transmissions for under $ 1,000. One close to me with 3,000 miles on it. I would guess $300-$500 labor would be fair,sound right?
I was just over 2k for the transmission work. Difference in cost is i am in Canada, so everything is just a little more expensive. (but you are pretty bang on if you factor exchange rates)
Old Oct 29, 2015 | 09:20 AM
Speedy4x4's Avatar
Default
Originally Posted by trocar
Sorry....
Complete rebuilt.
Original transmission out and a rebuilt replacement.
From what I was told, it was the most cost effective method of correcting the "blown" transmission.
What fid your mechanic say was the weak points in the nsg370?
How much did he charge for the clutch, pressure plate and flywheel?
Old Oct 30, 2015 | 08:59 AM
trocar's Avatar
Default Re: Kaboom
my mechanic told me that the weak link in the transmission was the bit that attaches the drivers seat to the transmission.
Said these things are pretty rock solid, however it is his belief that previous owner was hard on it (bad shifting and over stressing bearings with downshifts at too high a rpm) was the beginning. My sometimes zealous running thru the gears didn't help matters, and finally one thing lead to another and kaboom.
clutch is oem replacement, $1500 plus labour
Old Oct 30, 2015 | 03:37 PM
Speedy4x4's Avatar
Default
Did they change the flywheel and pressure plate also or just the clutch?
syfi
Mar 28, 2026 04:14 PM
Lockhouse
Mar 20, 2024 04:50 PM
Wes__Hutchinson
Jun 10, 2019 11:24 AM
crossfireusa
Oct 28, 2015 12:03 AM
Crossfireconv08
Jul 30, 2015 12:11 PM
