Cylinder Misfire Help
Old Feb 17, 2020 | 02:04 AM
  #61 (permalink)
Cotyt94's Avatar
Default Re: Cylinder Misfire Help
Hmm this guys problems are just like mine right now.
Old Feb 17, 2020 | 07:46 PM
  #62 (permalink)
bc75's Avatar
I was having the same problem. Cleaned mass air flow sensor and took throttle body off and my throttle body gasket was shot. Put new one on runs like new.
Old Feb 14, 2026 | 08:40 PM
  #63 (permalink)
tlhayes580's Avatar
Originally Posted by jamesmonter2
Ok So I just purchased a new MAF sensor and CamShaft Sensor and installed, Still stumbles, no power, throttle weak and rough idle. Other parts i just replaced and rechecked multiple times. New Wires, New spark plugs, new coil packs, new injectors, checked fuel pressure and is constant 52 PSI at idle and wide open throttle, new EGR valve, new air filters, new oil change and filter, new Bosch oxygen sensors, New seal on air intake, removed throttle body cleaned, oiled and replaced with new gasket. I removed the entire exhaust no plugs in exhaust and reinstalled. Any other suggestions? I am uploading a youtube video so you can hear the car. I will load the link soon. I am running out of ideas here.
This sounds like the same issue I am having . I also replaced MAF, Crank pos sensor. Then plugs, coils, and wires. Did you ever figure out issue? Contemplating a bonfire..... help please.
Old Feb 15, 2026 | 09:34 AM
  #64 (permalink)
8ighth Wonder's Avatar
Fuel pressure should increase under throttle not remain the same. Keep it simple. Fuel, Air, Spark. Before I changed all of those parts, I would have verified I had each one of those. 52 psi is low for that engine and it should increase under throttle. I would have checked the regulator first. I'm not looking at changing MAF sensors unless the fuel trims tell me to.
Old Feb 15, 2026 | 11:02 AM
  #65 (permalink)
zip439's Avatar
Any DTC ??
Did you check the EVAP solenoid? Take the line off that runs to the back of the car; Put a small vacuum on it. If you get gas you have found your problem.
Old Feb 15, 2026 | 08:31 PM
  #66 (permalink)
tlhayes580's Avatar
Did you ever solve this issue? I am having the same. was getting random cylinder misfire in multiple cylinders. Changed crank and cam sensor, dd ok for a few miles. Then back, did plugs, wires and coil packs. still having same issue. Making me want to use i for target practice.
Old Feb 16, 2026 | 11:57 AM
  #67 (permalink)
change out the front O/2 sensors even if u changed them before. make sure the connection is clean and dry
the Crossfire has a unknown o/2 sensor problem that does not show up on any diagnoses and only i know about it. LOL jim
auburnamphi
Mar 24, 2025 09:01 AM
dlang
Feb 14, 2023 06:44 PM
austinbarrylee
Sep 19, 2022 05:22 PM
griffinregan
Aug 7, 2022 12:04 PM
maxime75us
Mar 28, 2013 02:42 PM
