Rcm
Old Feb 3, 2019 | 01:24 PM
Oconnom's Avatar
Default Re: Rcm
Thanks for the clarification, I'll check the RCM for relay operating tomorrow morning (its dark and cold here in London!).
If my TCS relay is not operating on Run/On, would that cause a no start ?
Would love someone else check what they see on the pink/red wire on A2, I see 12v with ignition at On/Run and Start.
I hope you are correct and pulsing on and off is not correct, would make more sense if the enable signal to the PM was simply high/low
Mick
Old Feb 3, 2019 | 01:27 PM
Oconnom's Avatar
Default Re: Rcm
Just looked at the TCS wiring, seems the TCS relay gets 12v from ignition switch via a diode to operate the relay and the contact switches 12v to the SLA.
Old Feb 4, 2019 | 05:20 AM
Oconnom's Avatar
Default Re: Rcm
Tighed1,
Yes, just confirmed, Ign switch to On/Run - ECM and TCS relays hold operated and the Fuel Pump operates and then releases.
Have ordered a Pulse Module.
Do you know what voltage or condition should be present on Pulse Module pin 1B when ign switch is in Crank position ?
I'm seeing 12v.
Mick
Old Feb 4, 2019 | 10:40 AM
Oconnom's Avatar
Default Re: Rcm
Good news, I've fixed it ! Car starts OK. Whilst twiddling my thumbs waiting for the Pulse Module to be delivered via eBay, I thought I'd take another look at the RCM.
As I said before, the RCM looked perfect, all solder joints were clean and no sign of burning etc. I had already re-soldered the 3 points indicated in other posts and continuity tested all tracks, coils and contacts OK, so I decided to carefully re-solder every joint, plugged it and hey presto !
Thanks for your advice along the way.
Mick
Old Feb 4, 2019 | 12:14 PM
JSK's Avatar
JSK
Default Re: Rcm
Just took a cruise back thru this thread, PizzaGuy said to resolder all joints in post #9.
Old Feb 4, 2019 | 01:03 PM
Oconnom's Avatar
Default Re: Rcm
In fact it was post no. 6. On reviewing the posts this morning, it prompted me to give it a go. I must admit, I was subconsciously initially looking for something obvious like a burnt or broken track, or an obvious powdery dry joint but the RCM looked factory fresh. Just goes to show, what looks good on the surface may not be underneath !
Big thanks to PIzzaGuy
Old Feb 5, 2019 | 12:37 AM
tighed1's Avatar
Default Re: Rcm
Traction control relay should also be engaged.
Manually close it then see what happens when you try to start the car.
Old Feb 5, 2019 | 04:38 AM
Oconnom's Avatar
Default Re: Rcm
DJ, look at posts 23 and 24
tighed1
Jan 11, 2025 05:45 PM
blkXfire04
Sep 14, 2011 10:02 PM
dcspride
Oct 29, 2009 03:54 PM
NYPD-Crossfire
Oct 21, 2009 02:21 PM
chelseaccox85
Dec 18, 2008 01:16 PM
