Phantom Shifter Bushings
Old May 15, 2026 | 05:30 PM
NWGACarGuy's Avatar
Default Re: Phantom Shifter Bushings
Originally Posted by Americium
I may or may not dig into the project of pulling the shifter mechanism. I’m needing to sell the car so I may just disclose it to whoever is interested in buying it and hope it doesn’t turn them away. Interesting that the stiffer bushings make it harder to get into reverse. Nice work on figuring all that out!
I was going to sell mine, but now after sorting out all the quirks, getting the shifting slop out, and doing the throttle body and stealth airbox upgrades, I am finally loving how this car drives! It is one of the quickest (not fastest) and most nimble little cars I have ever owned. I learned again an old lesson that I had forgotten in all the details - Sooner or later (better sooner) you just have to chill-out on making the car perfect, and just basically drive the heck out of it. I avoid first gear whenever possible too. Second gear has plenty of pull for most starts.
Old May 15, 2026 | 10:41 PM
I remember my son took it for a spin and remarked about how low 1st gear is. I haven’t tried starting in 2nd but might give it a try. My car has around 80K miles on it and I noticed on the CARFAX report that the clutch was replaced at around 50K. So I have always tried to take it easy on it.
I have been on this forum and had a Crossfire for 19 years
and one of the fewest things I have ever read here is the need to replace our clutches on the 6 Speed Manuals
Old May 16, 2026 | 09:17 AM
NWGACarGuy's Avatar
Yes - it's very easy (and usually a mistake) to blame the clutch, when it is not the culprit. There are several easy tests out there to rule-out the clutch that involve taking off and/or driving in different gears under different loads (e.g. slow, uphill, downshifts, etc. - should be able to find some on You Tube). The "parts replacers" that pose as Techs and are happy to take your money often just sell you the replacement job rather than do a thorough diagnosis. Dealerships are notorious for this, then when you return a few miles later with the same problems they usually tell you that the now working part caused some other compromised part downstream to fail, and Ta Da! another part needs replacing! The best service you can get from Car Max is probably a wash and amateur detail. The entire shifter mechanism and linkage is a Rube Goldberg contraption that does everything the hard way with junk for parts. A DIY test drive using clutch testing methods will probably exonerate your clutch. Most Techs at Chrysler and MBZ dealerships get thrown by the bastard off-spring of the ill-fated marriage if they are willing to test it at all. Flush and fill the clutch slave cylinder and lines. Renew the transmission gear oil. Replace your bushings (or even shift more slowly and precisely) and I think your problem with improve. You can also remove the shifter boots from above and clean and lightly lube the ball and socket connections. Check your shifter assembly mounting screws too, as they sometimes loosen up and cause later and vertical slop. The shifter assembly and bushings are usually the culprits. Once you pull the mechanism and see the rods, connectors, and bushings you will see why.
NWGACarGuy
Apr 9, 2026 09:03 PM
MAYAman
Jan 24, 2026 02:57 PM
James1549
May 28, 2019 06:38 AM
Selbyl
Sep 22, 2015 09:31 PM
Doc
Aug 17, 2004 02:51 PM
