Door Sill issue
So I finally installed my illuminated sills and they light for 4 seconds and then go out. I have to unplug the transformer module to get to light again but still for 4 seconds at a time. Leaning toward defective module. Anyone replace theirs yet? Or run into same issue? Wiring correct feeding +12 volts on red wire - tapped into Red with Green Trace. Ground on Brown wire tapped into Brown with yellow trace. Test light across those wires functions like all others. Ideas?
You have a bad transformer. I had the same problem when I first installed mine. You need to contact Mopar and they will ship you a new transformer. I think I had to send mine in first and then they shipped me a replacement.
Dealers around here not much help. They cannot find specific part number for transformer... hopefully Chrysler Cust service is more helpful...
Nope just got off phone with em. "Gee dealer should have given you the address where to send part. I cannot find MOPAR Address in my system either." Go back to dealer.
Time to fix myself...
What number did you call to reach MOPAR to get them to send the replacement transformer?
I have the same problem and the parts computer at the dealership does not show a separate part number for just the transformer, only for the entire kit. I know these guys so they're not trying to be funny although they might not know where to look.
Customer support at Chrysler is saying the same thing and says that because it is an after market accessory, they can't help.
Any info you can provide would be greatly appreciated.
Thanks.
PHeez
Aug 11, 2015 01:30 PM
WindRestrictor
Jul 29, 2015 03:58 PM
