installing new headlights assy
Old Jan 3, 2010 | 01:22 PM
ron maness's Avatar
Default installing new headlights assy
here is the question rebuilding damaged crossfire hit in front lights were damaged the ? there are 4 mounting screws and on the bottom of light assy are 2 hex nuts adjustable do they sit on any bumpers on the light cavity where the light assy goes?
Old Jan 3, 2010 | 04:48 PM
Airscape's Avatar
Default Re: installing new headlights assy
Are you talking about the large ones for adjusting the beam hight etc? (the bottom screws go right into them) There are no bumpers that I can remember but they kind of slide into a specific spot. It's hard to explain without seeing it. If you have the tire off and the lining and such removed it is easy to see how things go together from the bottom. If your trying to work through the hole in the plastic it is almost worth it just to remove all the stuff and get a good look. Once you see how it all works you will be able to work through that little hole a lot easier next time. (was for me anyway)
Old Jan 3, 2010 | 05:34 PM
Larry Hitze's Avatar
When I changed my right side headlight I removed the grill and it made the change go alot easier. I didn't take the wheel off or anything, but what goes well for one person sometimes doesn't for others.
Old Jan 3, 2010 | 10:16 PM
ron maness's Avatar
thanks for your help airscape
xfireohio
Jul 20, 2020 12:03 AM
rperry52@live.com
Feb 14, 2019 12:18 PM
gp1200x
Dec 6, 2015 12:59 PM
pioneer4x4
Sep 24, 2015 11:17 AM
DLSchell
Aug 20, 2015 03:20 PM
