HOW TO replace headlight bulb. Pictured step by step instructions
  #101 (permalink)
Old 02-24-2013, 05:30 AM
Default Re: HOW TO replace headlight bulb. Pictured step by step instructions
Your pitures & step by step instructions on changing the Crossfire Headlamp bulb were most useful, but I had difficulty removing the plastic connectir plug from the old bulb. I finally did this by looping a thin plastic string around the back of the connector (like a lasoo), so I could pull it outwards, while wiggling it with my fingers! It finally came off, after which fitting the new bulb was no problem.
My main problem is Interior Noise, much louder than the Mercedes SLK on which the Crossfire is based.
Originally Posted by Mrmiata
Not a problem at all..
Now I have a question for the members.. If.. like in your case.. you don't have a clue whether your running 6000K .. 5000K .. etc. how would you know what to replace with? Granted they come in pairs so not like one white eye and blue eye syndrom... but if you wanted to keep what you had? I got the 6000K and they actually are bluer than what I originally anticipated..
  #102 (permalink)
Old 07-30-2013, 08:19 PM
where do I find the actual instructions on how to replace the bulb (low beam) in here I can't find the thread with pictures ?? My crossfire is a 2005 roadster sapphire Blue Silver.
  #103 (permalink)
Old 07-30-2013, 08:23 PM
Go to the very top of the page and type 'replace headlight bulb' into the Google Custom Search box.
Click on the first link listed.
  #104 (permalink)
Old 07-30-2013, 10:58 PM
Here..............................................
  #105 (permalink)
Old 07-31-2013, 07:31 AM
180, we gotta get our act together.
One day you tell people to use the search function ( as I did in the post prior to yours ),
and the next day you supply the link.........
  #106 (permalink)
Old 07-31-2013, 12:42 PM
All depends on if Dave took his meds
  #107 (permalink)
Old 07-31-2013, 02:34 PM
Mrmiata's Avatar
I wasn't going to risk it with a comment...
Best of luck to ya..
  #108 (permalink)
Old 07-31-2013, 03:49 PM
I like to think, and Dave, please correct me if I am wrong, that since we have met more than a few times and have shared several adult beverages, that you would allow me to jokingly talk about your lack of medication
I do NOT want to be on his bad side, Dave knows more about the part numbers and solutions to these cars than the engineers who built them...
  #109 (permalink)
Old 07-31-2013, 04:34 PM
Mrmiata's Avatar
I just count on him not remembering my comments come the next day!
We love ya 180..
Even though sometimes it sounds more like tolerating..
  #110 (permalink)
Old 07-31-2013, 04:39 PM
No offense taken here, my problem solving is done with search and the use of my memory on common faults.
I learn new stuff every day.
I found it funny that the OP posted his question in the very thread he was looking for. He asks his question in post #102 and is told to go to post #1.
  #111 (permalink)
Old 08-01-2013, 08:46 AM
OP:
  #112 (permalink)
Old 10-04-2013, 06:21 PM
Red face Re: HOW TO replace headlight bulb. Pictured step by step instructions
Originally Posted by Musclefan21
Ok guys, My passenger side low beam went out and since last time it gave me a HUGE headache, I decided to to a DIY for it.
This is actually an EXTREMELY EASY job which can be done under 5 minutes. I tried to go into as much detail as possible for those who has no knowledge, so, they could understand it better.
Do this at your own risk.
Enjoy:
Thanks for the helpful info,...I had a mechanic look at removing it and he finally suggested I take it to the dealership...instead I looked it up on the forum and did it myself. Yes girls can do this too!
Unfortunately because I did not take the rubber cap off in the first place I didn't realize it was there and it must have fallen off the car when driving. Now I need to locate another one...any ideas?
  #113 (permalink)
Old 10-04-2013, 06:57 PM
Do not go to this mechanic, I use the word mechanic loosely here, again.
Try MrMopar and his shop.
Or buy the kit that helps prevent moisture in the head light unit.
  #114 (permalink)
Old 10-04-2013, 10:10 PM
Mrmiata's Avatar
Edit to above.. yes you can get the clip back on.. you don't want to go there.. but you can do it.
Now ask me how I know..
  #115 (permalink)
Old 10-04-2013, 10:20 PM
Putting the clip on is quite easy, you put the index finger of one hand on the raised hinge of the unit and hold the spring slightly pinched together in the other hand. Slide the end of the clip under the tip of the index finger and feel the end enter the hinge point. Repeat this with the other end of the clip. You do not even have to look at what you are doing, it is all done by feel.
Tie the clip to a piece of string or something so that if you drop it you can find it easily.
  #116 (permalink)
Old 10-04-2013, 10:26 PM
Mrmiata's Avatar
Picture of 180.. he can actually reach in and clean the lenses..
  #117 (permalink)
Old 10-13-2013, 08:34 PM
mobilefitt's Avatar
Just changed bulbs with Sylvania HID like bulbs. Nice bright white, but I noticed that the passanger side light will not adjust high enough to luminate the road. I tried cranking it all the way down, it clicked and went down a step. I cranked it all the way down until the adjustment won't turn anymore, then I cranked it up. It seemed to come up well at first but it wouldn't angle high enough to match up with the passanger side light. I cranked that one down but I can only see about 15ft infront of the car. I read how one of the bulbs inserts tab up and the other inserts tab down so I turned the passanger bulb tab up. I thought I had figured it out but again, it didn't crank high enough. Any thoughts?
  #118 (permalink)
Old 10-13-2013, 08:38 PM
Mrmiata's Avatar
I think you got confused.. should be both tabs down on low beams.. and both tabs up on the high beams.. sounds like even though you "think" they are in the tab.. it isn't quite there..
  #119 (permalink)
Old 10-14-2013, 09:59 AM
mobilefitt's Avatar
Default
Thanks for clarity. Tabs down low beams. Tabs up high beams.
  #120 (permalink)
Old 10-14-2013, 02:39 PM
harbor's Avatar
Thanks to all who contributed to this thread. Replaced my orig factory Osram driver's low beam with a Hella (made in India) this weekend after it burned out just as I returned from the Dragon last week.
Project went well with no bloodshed, although my biggest problem was getting the plug off. A pair of small needlenose vise grips did the trick. Of course it took 3 tries to get the bulb tab correct so the beam was level. Forum instructions were a lifesaver.
Quick Reply: HOW TO replace headlight bulb. Pictured step by step instructions
