Fog Lights in a N/A crossfire
Old 10-26-2013, 07:21 PM
FabianMoody's Avatar
Default Fog Lights in a N/A crossfire
Hey guys,
With installing fog lights in the N/A crossfire are there any adjustments that I need to make for the installation. I dont know what adjustments I would need to make on installation and or if there are any. Im looking for any information on the setup. Any advice or information greatly appreciated. Thanks
Old 10-26-2013, 09:09 PM
Default Re: Fog Lights in a N/A crossfire
There is one adjustment, vertical. It has to be made after installation. There is an adjustment **** to use on the back side of the light assy. You can gain access to it through the door on the inner fender panel. Use a closed garage door to get them egual and a height you like.
Look for the white **** in the pic. If I remember correctly, you will need a torx bit to make the adjustment.
James
Old 10-26-2013, 09:58 PM
James
What does that do though? I was wondering more soo about how do I cut them on after installation like what triggers the fog lights to cut on?
Old 10-26-2013, 10:03 PM
Look for the white **** in the pic. If I remember correctly, you will need a torx bit to make the adjustment.James
It is actually a 6mm hex Allen key. I just measured one.
Old 10-26-2013, 10:05 PM
The light switch on the dash, you pull it out. I believe all models use the same switch.
Old 11-01-2013, 07:14 PM
Default
<p>&lt;p&gt;
&lt;font size=&quot;2&quot;&gt;The light switch on the dash, you pull it out. I believe all models use the same switch.&lt;/font&gt;
I appreciate that my boi I just tried that and its just that simple I appreciate it
Old 09-22-2017, 06:17 PM
James
Which which way do you turn the adjustment to make the lights go up clockwise or counterclockwise?
amatxcrossfire
08-15-2015 01:28 PM
chturner
06-23-2015 07:21 AM
blackpepper
06-11-2015 10:20 AM
MJPowers
06-08-2015 02:34 AM
WindRestrictor
06-01-2015 02:31 PM
Quick Reply: Fog Lights in a N/A crossfire
