Headlight low beam not working. Bulb and fuse are good.
Old 12-07-2018, 04:42 PM
Chiver79's Avatar
Default Headlight low beam not working. Bulb and fuse are good.
On my 05' Crossfire the passenger side low beam just quit working. Changed the bulb and checked the fuse. Still doesn't come on. Double checked the old and new bulbs, both measure resistance with my multimeter, so they should be good. Measured the fuse in the dash fuse panel with the headlight switch on, voltage at both fuse terminal tops. Measured voltage at the bulb connector, only .7v there. Is there a relay somewhere for the headlights? I know there's the bcm relay box by the battery, does this manage headlight power as well?
First post here for me, but I've been viewing for about a year now. Thanks in advance for the assistance and thanks a ton for all the information here I've used this year!
Old 12-07-2018, 05:29 PM
Default Re: Headlight low beam not working. Bulb and fuse are good.
There are no relays involved, best option is to meter the voltage at the headlight connector to see if problem is internal to the headlight, or external wiring.
Old 12-07-2018, 05:48 PM
Chiver79's Avatar
The connector is reading .07v
Old 12-07-2018, 05:54 PM
No, not the INTERNAL bulb connector, measure at the connector that goes to the headlight.
Old 12-07-2018, 06:00 PM
Chiver79's Avatar
Voltage low there too
Old 12-07-2018, 07:03 PM
Then unfortunately you have a wiring problem, as you have most likely already concluded.
Old 12-08-2018, 08:29 PM
I am hoping you are using a ground separate from the wire at the headlight bulb connector? Check Illumination Control Module (ICM) pins 3 and 5 for the 12v (system voltage) heading to the bulbs when set for headlights to be on. If pin 3 is not hot and pin 5 is hot, you may need a new or replacement ICM module. If both pins 3 and 5 are hot, you have an open in the wiring harness from output pin 3 to the headlight connector. Hope this helps!
Old 12-08-2018, 08:38 PM
Chiver79's Avatar
Where is the ICM located?
Old 12-08-2018, 08:41 PM
The ICM is just another name for the headlight switch assembly.
Old 12-08-2018, 08:42 PM
It is the light switch, the whole assembly. Search ICM or light switch should help. Good luck!
Old 12-11-2018, 04:58 PM
Chiver79's Avatar
Pins 3 and 5 are hot with the switch in the on position. Looks like I may have to run a new wire. Is the firewall cable access under the driver side fuse box in the engine bay?
Old 12-11-2018, 06:08 PM
That looks correct to me, but what do I know?
Old 12-12-2018, 07:10 AM
waldig's Avatar
In a word, Squirrels may be your issue, wire chewed?? Do you have any rodent tracks, nuts , in the engine bay?? Woody I have lost on several vehicles turn signals, ABS wiring, and fuel pump connector....
Old 12-12-2018, 10:06 AM
When squirrels build their nests they like to be off the grid, so they get rid of the wiring.😉
My wife saw a Jeep and the engine bay was so packed with pine cones that the engine was not visible, two garbage cans of cones were removed from it. The owner never lifted the hood and just said it was running rough when he drove it into the dealership.
Old 12-12-2018, 01:21 PM
Chiver79's Avatar
Lol, no signs of rodents...
Old 12-13-2018, 05:06 PM
Chiver79's Avatar
Just realized the pin assignments are actually flipped from the above pic when looking at the connector from the front. Yellow is in the top left position, which has voltage.
Conclusion: My open circuit is in the headlight assembly.
How difficult is the headlight assembly to open up? I already understand the difficulty of removing it, as I had to adjust the driver side a few months ago from the under bolts. It required removing the inside fender wall.
Old 12-14-2018, 08:59 AM
I would not try opening it up, I would run 2 wires from the headlight connector to an H7 connector through the rubber seal cap.
Old 12-14-2018, 09:10 AM
Chiver79's Avatar
Saves me a day of work and no risk of screwing up the assembly. Great advice! Thanks!
Old 12-14-2018, 09:18 AM
No problem, good luck !
thenickzone
04-05-2019 09:59 PM
IGot2P
04-21-2015 08:45 AM
keith of bellingham
10-21-2014 03:38 PM
NjRichieRich25
11-12-2013 03:21 PM
robertms49
10-31-2012 06:50 AM
Quick Reply: Headlight low beam not working. Bulb and fuse are good.
