Brighter headlight
Can anyone recommend a brighter low beam headlight bulb for our Crossfires. Is there an LED can bus bulb we can use? The older the headlights get the dimmer the low beam driving lights seem to get.
I think these are pretty bright for a plug and play Bulb
They cast a whiter light than conventional bulbs
I have them in my Roadster
H7 bulbs
H7 bulbs
Needswings sells the PIAA bulbs and they work really well. I have used them for years, white light. I think it is 5,000 k. No need for LEDs.
Twisting the long stem at the rear of the headlight housing counter clockwise will raise the beam for both low and high beams.
Go HID. HID bulbs emit light down the centerline just like the original H7 therefor you are matching the reflector to get light into the projector to get the light down the road.
Go with the Kensun 35W H7 6000K HID kit. Ive had them in for six years with no problems. Highly recommend these. https://kensun.com/collections/hid-c...5_w_hid_kit_h7
SparkieSRT6 used 100 watt bulbs and he found they caused no problems. I have some but have not tried them.
They are illegal, 70 watt being the max allowed but who can tell these day's
I tried those so called brighter bulbs, against a white wall and compared the old with the new, I could see little if any difference, I got distracted and forgot to put a matched pair in. I have driven them like that for years now.
No, but I did put in Morimoto 2-Stroke H7 LED's in both low and high. Incredibly bright.
Here's a link of Sylvania low beam headlight bulbs for Crossfires
https://www.sylvania-automotive.com/apps/vlrg-us/Vlrg/
So I put in the 100 watt bulb on the left high beam, used the Hella Optilux H7, will try that for a while and see how the wiring holds up. Since the high beams are used off and on it should not be as demanding as in the low beam light continuous use.
i got some Morimoto HIDs but you need to do a lot of wiring and I have held off on using them, although using them in the low beam should be OK, but some say HIDs do not like being cycled a lot.
Can anyone recommend a brighter low beam headlight bulb for our Crossfires. Is there an LED can bus bulb we can use, similar to the plug and play options available for a Toyota Land Cruiser Lightbar? The older the headlights get the dimmer the low beam driving lights seem to get.
