Strange noises when the windshield wipers are moving
Old Oct 1, 2025 | 04:03 AM
Myopic's Avatar
Default Strange noises when the windshield wipers are moving
This morning, it was raining in my city. I got in my car, turned on the windshield wipers, and heard strange noises that occur when the windshield wipers are moving. I recorded a short video with my smartphone, but I'm not sure if it's audible – here it is.
I drove to a car repair shop and was told that the wiper control mechanism was worn out and that I should look for a used one in good condition online.
What do you think?
Has anyone else had a similar problem?
Old Oct 1, 2025 | 06:48 AM
Myopic's Avatar
Default Re: Strange noises when the windshield wipers are moving
At the same time, I replaced the old articulated windshield wipers with new BOSCH AeroTwin 3397118905.
Old Oct 1, 2025 | 08:17 AM
xintersecty's Avatar
I think you should take it apart and examine it yourself. Here is a good post to open that section up and remove your alarm (or replace it) at the same time. I suspect, it's fine and sounds like a loose bolt allowing it to rattle.
https://www.crossfireforum.org/forum...tml#post989003
Old Oct 1, 2025 | 09:49 AM
Myopic's Avatar
@xintersecty Thank you.
At the moment I bought two black plastic wiper arm bolt covers at a Mercedes dealership. It cost 7 dollars each.
Old Oct 1, 2025 | 09:51 AM
Also, when the cowl is off, clean the drains under there.
Old Oct 1, 2025 | 11:16 AM
Good advice there ZERACER. Also why remove the alarm? The batteries in the alarm go bad and then the alarm drains the main battery.
Old Oct 2, 2025 | 01:43 AM
I think I have seen that post before! LOL
Old Oct 2, 2025 | 01:54 AM
What do you think?
https://youtu.be/GIWGFEdYMOM
It's hard to tell from the video, but it sounds like the linkage for the wiper arms is loose or slacking.
Try this: With the car off and the wipers in the normal resting position, gently move one of the wiper arms with your hand. Check to see how much "play" or movement is in the arms. Does one arm move before the other one starts moving? If both arms move at the same time, then the motor may have play in it, or the part that connects to the motor may be worn out. If you have a lot of movement then that is the problem that is creating the noise.
Also listen for that noise when you do it.
I don't know if there is a way to adjust the arms or not. If not, then you will have to replace the linkage. Looking at the pictures from my post, the linkage seems to be easy to replace.
Good luck!
Old Oct 2, 2025 | 06:53 AM
Myopic's Avatar
@M60A3Driver Thanks for the advice
I checked, and there is a slight play in the mechanism. But today I drove the car and that strange noise from the wipers was no longer there.
The whole problem is that you can’t buy a new mechanism, and if I have to spend money on a used one taken out of another car, I have no guarantee that it won’t have a similar fault. That’s why for now I’ll just keep observing how the wipers are working.
Old Oct 3, 2025 | 01:30 AM
Did the noise stop after you had replaced the old wiper blades?
Old Oct 3, 2025 | 10:21 AM
Myopic's Avatar
@M60A3Driver Yes, but I don't know if I should connect the two.
There's no strange sound at the moment, so I'll keep an eye on it.
Old Nov 18, 2025 | 09:53 PM
jovoke's Avatar
I drove to a car repair shop and was told that the wiper control mechanism was worn out and need help filing your claim? that I should look for a used one in good condition online.
What do you think?
The wiper control mechanism is likely worn, and replacing it is the correct solution. A used part can work if in good condition, but a new or remanufactured part is more reliable.
No704
Aug 9, 2025 04:37 PM
Ronman
Jan 29, 2015 07:21 PM
bluefire2005
Mar 26, 2011 09:24 PM
trptdaddy
Feb 16, 2008 12:01 PM
bonsterbum
Mar 5, 2004 11:24 PM
