Parking Lights Driver Side Remain On
Old Dec 30, 2025 | 07:17 PM
Cmbankos's Avatar
Default Parking Lights Driver Side Remain On
CLP No water Found
CLP No water Found
Only Code I got, unsure how to scan for BCM or other relays?
I'm curious if there are any more relays to check in between the CLP and the Illumination Switch? I'm currently just taking the fuse out for the driver side parking lights. Any input is appreciated. I think the angle sensor code may just be from me disconnecting the battery to try and reset the lights. I did the steering wheel turn and driving to reset ESP.
Old Dec 30, 2025 | 08:51 PM
Default Re: Parking Lights Driver Side Remain On
Here is a really dumb question but must be asked. Is the light switch in the 'off' position? Turing the switch all the way to the left is not off.
James
Old Dec 30, 2025 | 08:58 PM
Cmbankos's Avatar
Yes it is really in the off, center position
Old Dec 30, 2025 | 10:50 PM
what James is referring to , is on all crossfires the headlight switch has a left parking and a right parking light notch
that U can leave either side on (if U want) on so look at your switch and turn off your left side parking lights.
Old Dec 31, 2025 | 01:26 AM
Do you have LEDs?
If so replace them with the standard bulbs and see if the problem goes away.
Old Dec 31, 2025 | 09:39 AM
Cmbankos's Avatar
Yes the switch is in the off position, dead center position. I don't have any LED lights. All standard bulbs
Old Dec 31, 2025 | 05:47 PM
I would replace the Illumination Control Module. Several used ones on ebay.
Here are the instructions:
Old Dec 31, 2025 | 05:48 PM
Cmbankos's Avatar
I was thinking that but wasn't sure if there was anything else to check before replacing parts. Any in between relays. Should I remove and check the contacts of the CLP as well?
Old Jan 2, 2026 | 09:48 AM
NeedsWings's Avatar
i had this issue on my yellow car, turned out to be corrosion on the thin black plug to the central locking pump. unplug them and verify.
Old Jan 2, 2026 | 04:33 PM
Cmbankos's Avatar
So I checked all of the male and female electrical connectors on the CLP and found no moisture or corrosion. I ordered a ICM/light switch off eBay. I'm going to try replacing that next. I'm not sure what else to check. When the fuse is in, the driver side parking lights remain on when the switch is in the off position and the light bulb indicator is on the dash. When you turn the lights on, the bulb indicator goes off.
Old Jan 3, 2026 | 11:19 AM
Nelson G's Avatar
You may want to read through this post. If you are replacing the headlight switch, you might want to make this upgrade for safety's sake.
https://www.crossfireforum.org/forum...ml#post1000209
scottishcrossfire
Oct 10, 2023 12:59 PM
JOE'S BLACK SRT6
Jan 27, 2020 06:12 PM
willnap
May 16, 2019 08:40 PM
AmCross
Mar 27, 2012 09:49 PM
purdy2005crossfire
May 16, 2011 05:30 PM
