Key housing
Old Jul 8, 2020 | 06:26 AM
forjox's Avatar
Default Key housing
I知 sure this topic has been discussed before and I知 sorry for a repeat. Has anyone had good luck buying a replacement key housing and having it work?
Old Jul 8, 2020 | 01:11 PM
Default Re: Key housing
Are you talking about swapping your Key FOB insides to a new key housing? If so, yes it is not that difficult just be sure you don't forget the RFID chip that communicates with the screem There are instructions on this site, just use the search option. If you need a new key make, SOS Diagnostics does it for about $250.00 to $300.00
Old Jul 8, 2020 | 03:14 PM
It DOES seem like finding new cases is getting harder and harder.
Old Jul 8, 2020 | 04:00 PM
but if u are talking about ,your key will not turn there is a easy fix and cost nothing if u do it yourself.
https://www.crossfireforum.org/forum...ru-2006-a.html
Old Jul 8, 2020 | 09:48 PM
forjox's Avatar
Thanks, I just need the housing as the original has worn button covers. I’ve seen a bunch on eBay, but wondered if they really fit?
Old Jul 8, 2020 | 09:59 PM
if u find a case all of the internal parts from your key must go into the new case.
https://www.crossfireforum.org/forum...estroying.html
Old Jul 9, 2020 | 12:58 AM
On eBay there are some that say they are for the Crossfire and SLK, get one of them. https://www.ebay.ca/sch/i.html?_from...cases&_sacat=0
Some others look the same but the old OEM to key does not fit.
I fitted all the old parts in with no trouble, do not lose the chip in the case and do not damage the circuit board.
https://www.crossfireforum.org/forum...ob-tom2112.pdf
Old Jul 9, 2020 | 12:11 PM
forjox's Avatar
Thanks everyone, I ordered a housing and we値l see how it goes
RICKFRINK
Aug 15, 2023 12:04 PM
Wes__Hutchinson
Mar 5, 2023 09:40 AM
smokey847
Jan 3, 2019 04:46 PM
ssammons
Apr 24, 2014 04:36 PM
Uzi
Apr 26, 2011 07:40 PM
