Fire Extinguisher
Old Sep 1, 2010 | 04:49 PM
Default Fire Extinguisher
Putting a CD player in the trunk left me without a space for the small fire extinguisher I always carried.
So I mounted the extinguisher bracket on a piece of wood, painted it black (the fastest color) and added some Velcro hook strips to the bottom.
It does not move around and the weight is enough to get a good grip.
It does the trick so I think I'll give another couple of coats of paint and round off the edges.
Old Sep 1, 2010 | 05:03 PM
Infinite's Avatar
Default Re: Fire Extinguisher
I hope its simply not an ABC extinguisher, they dont do anything for automotive fires that involve fuel/oil.
Old Sep 1, 2010 | 05:51 PM
You could have just used your cupholder:
Old Sep 1, 2010 | 06:03 PM
Joliet John's Avatar
That doesn't make sense since B fires are fuel. Doesn't ABC mean it works on A, B & C class fires? The only thing not covered would be D class fires (burning metals), which are pretty rare.
Old Sep 1, 2010 | 06:40 PM
  • Class A extinguishers are for ordinary combustible materials such as paper, wood, cardboard, and most plastics. The numerical rating on these types of extinguishers indicates the amount of water it holds and the amount of fire it can extinguish.
  • Class B fires involve flammable or combustible liquids such as gasoline, kerosene, grease and oil. The numerical rating for class B extinguishers indicates the approximate number of square feet of fire it can extinguish.
  • Class C fires involve electrical equipment, such as appliances, wiring, circuit breakers and outlets. Never use water to extinguish class C fires - the risk of electrical shock is far too great! Class C extinguishers do not have a numerical rating. The C classification means the extinguishing agent is non-conductive.
  • Class D fire extinguishers are commonly found in a chemical laboratory. They are for fires that involve combustible metals, such as magnesium, titanium, potassium and sodium. These types of extinguishers also have no numerical rating, nor are they given a multi-purpose rating - they are designed for class D fires only.
This one is a B C so if it gets into the upholstery it's toast, I just hope I am not in it at that time and get toasted as well.
That's a good point, but in a fire maybe that's the first thing I would want to see burnt.
Old Sep 1, 2010 | 11:04 PM
]This one is a B C so if it gets into the upholstery it's toast, I just hope I am not in it at that time and get toasted as well.
Actually, it would likely work fine on the upholstery. Stay away from the spicy food and you likely won't ever have your upholstery catch fire!
roar
Jun 15, 2022 11:46 AM
unarel32
35
Oct 6, 2015 05:53 AM
miscetera
Oct 5, 2015 11:40 AM
Charlesl
Sep 30, 2015 10:46 PM
rmcdaniel12
Aug 7, 2015 01:37 PM
