Why do the doors sound so cheap?
Old May 9, 2012 | 10:42 AM
smokey847's Avatar
Default Why do the doors sound so cheap?
The doors on my SRT sound so cheap when you close them, and God forbid close one of them with the windows down--sounds like you pulled up in a Geo. They are so light, that it literally sounds like something is breaking when you close them. All of my passengers have a tendency to close the door too hard because they are so light, so this one is remarkably worse than the drive door.
Is there anything I can do to help insulate this? Does anyone else have this problem?
Old May 9, 2012 | 10:46 AM
PNA's Avatar
PNA
Default Re: Why do the doors sound so cheap?
Maybe you have aftermarket doors. My doors are heavy and solid. I agree that closure with the windows down results in a less than solid sound but many cars sound that way.
Old May 9, 2012 | 10:50 AM
smokey847's Avatar
I retract my statement--the doors are, indeed, good and heavy, but the passenger door in particular sounds like something is loose inside when close with the windows down.
Old May 9, 2012 | 11:31 AM
Same here. My red roadster was nto like this. I intend, SOMEDAY, to take the panel off the door and look at the integrity of the window regulator assembly.
Old May 9, 2012 | 05:46 PM
Squirrel Crusher's Avatar
I have two spare doors. I haven't checked their weight,but you want believe how heavy our doors are. Squirrel Crusher
Old Jun 13, 2012 | 08:57 AM
AlphaTrion's Avatar
Yea I have that same problem. They creek and squeak. When pushing the door open or when you are riding. I hate it. If you have the same problem that I have. I think the problem is a lack of thin felt in between the different pieces of door panel plastic. The panels are so tight they rub together. It's a common tactic car companies use to reduce the squeaks buy putting some thin felt in there. Maybe Crossfires don't have this. I'm not taking the door apart to find out. It's built like a tank, but that squeak makes it sound like an 85 Buick.
Old Jun 15, 2012 | 06:50 PM
Airscape's Avatar
Can't remember if there is a TSB or not but the noise when closing the door with the window down is documented. I am not sure if that is the regulator or the track hardware but there is actually something loose in there hence the sound. Dealer can fix but I know they were breaking the interior door handle in the process for some people, searching door shatter or other door noise like terms should get you more info. Mine does it but I don't have the windows down when closing enough for it to bother me. Will prob take a look when I replace door speakers.
Old Jun 15, 2012 | 10:59 PM
The inside of a door.
Old Jun 21, 2012 | 10:59 AM
kingtj's Avatar
Ah! Good info, and thanks for sharing that! A really noisy driver side door was one of the first things I noticed with my '05 SRT-6 convertible when I bought it. It actually has a couple of different issues.
First, when you open or close the door, you hear the hinge make a "pop" noise. I'm not sure if this can just be fixed by lubricating the right spot, or if something is actually worn and needs replacing?
But with the window rolled down, yes, something vibrates in the door when you shut it. I assumed it was the window glass itself, loose in its track when it's rolled down. But sounds like it's a known problem with something else inside there then!
Old Jul 1, 2012 | 07:14 PM
jacobcmiller's Avatar
I agree. It's especially terrible with the trunk lid. Everyone has the tendency to slam the doors...it's like come on! You barely need to tap the trunk lid to close it! Haha
Old Jul 1, 2012 | 08:54 PM
The pop is probably the catch that stops the door in two positions of open, grease may solve it, but it never did on my old Concorde and LHS.
Old Jul 13, 2012 | 03:35 AM
J-Walk's Avatar
The trunk.. it's terrible. The stoppers on the trunk have worn away the paint on my xf. And the slamming.. the last time I went to Country Buffet in Mi, the customs officer felt the need to show off to his friends and just gave her nuts. I thought the car was going to bounce up off the pavement.
The doors with the windows down makes me every time I close them. Even if you try to do it gently, you still get that noise.
Old Jul 13, 2012 | 06:44 PM
Same. Out of all my friends who frequently cruise around in my car with me, one of them doesn't slam any of the doors.
Old Jul 15, 2012 | 09:02 AM
TomStratRT's Avatar
We have very "clunky" doors. But according to one of the new VW commercials, doors that close with a loud clunk apparently indicates that it's great quality.
Old Jul 15, 2012 | 09:14 AM
user 72983's Avatar
Banned
It's hard to get the wife to close the doors or hatch without slamming them.
They really close effortlessly.
Old Feb 26, 2013 | 01:23 PM
jrf05's Avatar
I was going to add, my doors are heavy and very solid, a trait usally shared by all german autos, I have had no issues with squeaking or any other noises that sound funky
Old Feb 26, 2013 | 07:42 PM
user 72983's Avatar
Banned
With windows down...the doors closing is rather loud.
Old Jun 7, 2013 | 06:22 AM
AussieXFire's Avatar
I own a 1977 Cadillac Eldorado Biaritz, here in Australia, one of only 2 or 3, and I must tell you, the doors of the Caddy are long and heavy, but you close them, and there are lots of crashes and bangs.
I don't slam the doors when the windows are down.!!
Old Jun 7, 2013 | 06:46 AM
arado's Avatar
the doors on my car close with a satisfying sound. like a bank vault door. gary....
Old Jun 7, 2013 | 10:32 PM
SRQfun's Avatar
You may want to check the guts of your doors. Has someone taken the soundproofing out? Mine sounds solid & Aussie I also have a '77 Eldorado Biarritz and when I slam the doors the only noise those doors make are compared to a bank vault shutting..
