Wet Passenger Side Floor
Old Oct 13, 2016 | 07:16 PM
kurama04's Avatar
Default Wet Passenger Side Floor
After a lot of rain, discovered my passenger side carpet was soaked. Could feel under glove compartment where water leaked in. Not sure what problem could be. Help!
Old Oct 13, 2016 | 08:02 PM
Mrmiata's Avatar
Default Re: Wet Passenger Side Floor
You will find many post on this with a search.. "typical" problem is leaves in the windshield cowl venting.. Pull the wipers and cowl and clean.
Old Oct 13, 2016 | 08:03 PM
Mrmiata's Avatar
https://www.crossfireforum.org/forum...ight=wet+floor
Old Oct 14, 2016 | 01:53 PM
Get that water out of the lower compartment of that passenger side! I say this because if the carpet is wet, then there probably is a puddle below the carpet. You do not want all that wiring/stuff there to sit in it (may be too late already).
If you don't have the amp/related wet there, it will be good for you. Check that area!
Old Oct 14, 2016 | 02:36 PM
The TCM is also there snuggled up next to the amp on automatics.
Old Oct 15, 2016 | 01:55 AM
Hi George, George here. Yeah, I covered that under 'stuff' and 'related'. I had a brain flatulation out the ears and could not picture the layout.
05srtsix
Nov 10, 2016 02:03 AM
rush549
Oct 15, 2016 04:27 PM
Firstpoet
Oct 2, 2016 11:51 AM
Hal B
Sep 27, 2016 05:11 PM
ShawnQ
Sep 24, 2016 09:57 AM
