An hissing sound coming from the vents !
Old Sep 24, 2019 | 11:33 AM
georges99's Avatar
Default An hissing sound coming from the vents !
Hi !
I have "Skeel" or High pitch sound coming from the vents when I put on the a/c. It shuts off when I am only using the vents.
It sounds like a vacuum leeks. Is there any vacuum relay under the dashboard ?
Thank you.
2005 Roadster limited .
Old Sep 24, 2019 | 09:13 PM
Sussudio's Avatar
Default Re: An hissing sound coming from the vents !
[QUOTE=georges99;930067]Hi !
Thank you.
2005 Roadster limited .[/QUOTE
When was the last time the cabin filter was changed?
Old Sep 26, 2019 | 08:25 PM
Sounds like leaf debris in the squirrel cage blower to me. Raise hood, remove all the torx screws that hold the plastic cover under the wipers, and pull it free.
Then, vacuum the blower and passages out under there. My Graphite got to making noises and when the guy put the new windshield in, he saw the crap and cleaned it out for me.
No more noise.
Old Sep 28, 2019 | 10:40 AM
georges99's Avatar
Hi !
Actually, It is changed once a year.
Take in consideration that the car is in storage all winter long.
Old Sep 28, 2019 | 10:41 AM
georges99's Avatar
Thank you for the suggestion.
I will check it this weekend.
Thank you again.
Old Sep 28, 2019 | 07:40 PM
There are vacuum valves under and behind the dash, one is under the glove box. Finding the leak maybe be a problem. The valves work without air blowing in the system and this should help.
crossvic
Jun 10, 2018 03:30 PM
AC/No DC
Aug 20, 2014 12:44 PM
Tommyj
May 28, 2014 05:54 AM
samo59
Oct 29, 2009 03:24 PM
MAGNATUDE
Jul 18, 2009 09:37 PM
