Question on Problems with Convertible Mechanism
Old Nov 19, 2014 | 07:48 PM
woofie's Avatar
Default Question on Problems with Convertible Mechanism
I have a 2005 Conv. I went to raise the top a week ago and on the drivers side one the links was broke on the hardware that raised the top. Looks like a clean break in the metal but not sure how it happened. The top has stopped on the way down since I have owned the car and the previous owner had the same problem. You had to tap it on the part that rests on the windshield and then it would continue down, not sure if this caused the problem.
Looking for anyone with a similar problem and maybe how to fix it other than replacing the whole mechanism. My first post on the forum so thanks in advance for any help.
Old Nov 19, 2014 | 07:58 PM
Default Re: Question on Problems with Convertible Mechanism
Is it possible to post a picture ?
I believe all that hardware is aluminum, may be able to get it welded if you can get it off.
Old Nov 22, 2014 | 12:39 PM
woofie's Avatar
These are the pictures I took of the broken mechanism on the conv top on my 2005 Crossfire. Not sure if you can remove the part that is broken and have it welded. Any suggestions?
Old Nov 22, 2014 | 01:12 PM
RED DOG's Avatar
I may be able to help but I can't visualize from your photos exactly where that broken piece is located. I have a complete convertible top framework. Can you better describe the location of that broken piece and can you post a better / larger photo OR e-mail me those photos you have so I can blow them up for a better look? RedDogNumber1@aol.com
Old Nov 22, 2014 | 03:44 PM
Bob, if you open his gallery you can see the pictures. It's the scissor link part of the frame assembly.
Old Nov 22, 2014 | 04:18 PM
How did that get broke?
Probably letting college-age cheerleaders sit on his top!
(I guess I will avoid making that mistake....)
Old Nov 23, 2014 | 08:36 AM
RED DOG's Avatar
Thanks for that tip George . . . Now I can see it! I'll go see if that section / part is removable from my top framework . . .
Old Nov 23, 2014 | 09:32 AM
RED DOG's Avatar
Hi Woofie, I have the part you need . . .
It is held in place by three pins with retaining clips . . . . a mounting pin & clip at each end and one fulcrum pin & clip. $125.00 including the three pins with their retaining clips delivered to your door. Payment via PayPal. Please e-mail me directly at RedDogNumber1@aol.com if you want it . . .
Old Nov 23, 2014 | 10:03 AM
Once again, Bob to the rescue !
( Don't complain or haggle about the price, you are NOT going to find it anywhere else. )
KDW4Him
18
Sep 1, 2021 05:47 PM
Hoppy
Dec 7, 2018 07:36 AM
gblack32
Sep 7, 2016 08:27 PM
Bayukbros
Jul 17, 2015 04:22 PM
Bayukbros
Jul 17, 2015 11:21 AM
