Starting Issues
Old Jun 11, 2020 | 10:23 PM
reriksen's Avatar
Default Starting Issues
Hello, My wife and I bought a 2005 Convertible about 4 weeks ago, the car started acting up about a week ago and we would attempt to start the car, power to all the lights and instruments but would not try to turn over. Wait a little and then the car would start. The battery was load tested and then replaced, same problem two days later. Tried disconnecting the two cables based upon a suggestion and then reconnecting them and the car still did the same thing. Started this afternoon drove it a short distance and the car did not start - several hours later it did start. Any suggestions?
Old Jun 11, 2020 | 10:29 PM
Default Re: Starting Issues
send your RCM,,,,,,, to https://www.crossfireforum.org/forum...,,,,,don't even try to fix it your self just send it to tighted1 a new one cost 3 to 4 times what tighted1 charges and the new one will fail also so buy a new one, send your old one to tighted1, ALWAYS KEEP A SPARE IN YOUR CAR>
https://www.crossfireforum.org/forum...-no-start.html
Old Jun 11, 2020 | 10:38 PM
reriksen's Avatar
Send it to where? Do you mean the connections should be re-soldered?
Old Jun 11, 2020 | 10:43 PM
I sent u the link in the other post --------
don't bother soldering it ,, you need a relay replaced.
Old Jun 21, 2020 | 12:45 PM
THETESTER's Avatar
For clarity I am in the UK. Just Curious how much a new RCM costs in the good old US of A. I have just found a supplier of "NEW" units in the UK and they are asking £165 this is about $200. Is this about right?
Cheers
Mark
Old Jun 21, 2020 | 01:13 PM
Cheers
Mark
u can order from rockauto.com
CHRYSLER > 2005 > CROSSFIRE > 3.2L V6 > Electrical-Switch & Relay > Computer Control Relay Price
STANDARD MOTOR PRODUCTS RY1562 {#1705450305, 5099007AA, 68002488AA} Fuse Panel w/ Fuses Included Info
$111.79
Old Jun 21, 2020 | 04:32 PM
Do this.
Get in car, turn key to START, if the starter does not engage, release key so it goes back to "on".
Wait 30 seconds.
Does the engine fan warp up to high speed? (You WILL hear it.)
If yes:
It is almost certain the RCM's engine control relay output is bad. THis can be due to fractured solder on the RCM, bad relay on the RCM, blown fuse number 2 on the RCM (not your issue because yours starts at times).
A replacement RCM would probably fix this. It is POSSIBLE you have a low battery, but in such cases, letting the car sit won't make it start later on. My money is on the RCM.
If no:
We have some more detective work to do...
Old Jun 21, 2020 | 06:06 PM
THETESTER's Avatar
$111.79
Many thanks, appreciate the link.
Old Jul 7, 2020 | 09:37 AM
Bilaal's Avatar
Hi guys I’m new here...
Just wanted to say thanks... I read this thread and realized that my RCM was acting up. I was have the issue where the car wouldn’t start and the fan would warp to high speeds..
I removed the RCM re soldered the 3 pins, i also noticed that one of the relays had slight charring and was stuck closed... I cleaned it out and viola! Started immediately.
Old Jul 7, 2020 | 10:51 AM
Buy a new one and send the original to TJ for a rebuild and keep it for a spare. The other relays will fail eventually.
eragonmp3
17
Mar 15, 2016 05:02 PM
Raptor
Jan 15, 2013 04:16 PM
reni00
Mar 3, 2012 06:05 PM
NDguy23
Jul 1, 2011 09:44 PM
Wilsy
Mar 13, 2011 07:25 AM
