Convertible Problems
Old Jul 27, 2025 | 05:55 PM
hross's Avatar
Default Convertible Problems
Hi, I just got my first Crossfire two weeks ago. Enjoying it so far, but I can't put the top down. After looking at the wiring diagram and trouble shooting the pins at the "Power Top Controller Module". I found that I have a bad "Roof Open Switch" also called "Top Open Switch". I located it on the passenger side of the top. Tried to see if I can remove it from its bracket but it seems to be a one piece unit. has anyone on here been able to fix or replace this switch. Can you tell me how. My other thought was to just short pin 7 to ground so it will work. Any thoughts? Thanks in advance.
Old Jul 28, 2025 | 09:36 AM
Default Re: Convertible Problems
You can manually put the top down or splice the wires to the switch. Just be sure to always unlatch the top from the frame before pushing the button.
Old Jul 28, 2025 | 04:44 PM
hross's Avatar
I noticed that on the "Roof Open Switch" it didn't click when I depressed it. It looked like the rubber boot wasn't allowing the switch to go all the way up. I cut of the boot of with a x-acto knife and moved away the pieces. Now it is able to travel all the way up and clicks when depressed. Retired the top and it works. But a new problem surfaced. When the top is going down the back of the top (glass part) doesn't fully seat. It stays open about an inch. Any ideas?
https://www.facebook.com/photo.php?fbid=23993547946970636&set=p.23993547946 970636&type=3&__cft__[0
Old Jul 28, 2025 | 07:22 PM
That works for the divider switch, not the top open switch. If you jumper the top open switch, the PTCM will alarm because this means the top cycle is not complete.
This will also upset the sync, the "top open" switch must open when you pull the top down onto the windshield frame, as pin 7 must go high, indicating a completed cycle.
I do not believe the rear bow latch will engage with that sensor showing "top open" as well.
Old Jul 28, 2025 | 07:25 PM
=AZUgIV3Ot_Fq_M1YiCCS7S9xOBB49Vy50RgRauyUjSIERemT7 2wOzQvp65qav5jogFg6hCh7cZ0b4UBAmsfKOnIuXvC0PCGeYQz kDtdJ75sVUDKbsSDcmLGOd8dNEpxiXhlfoXRWZEF1LCiXI6cJj viE&__tn__=R]-R]No photo description available.
What you are saying is that the bow or "rear bow" does not latch into the tonneau lid. This can be one of several issues, including the "top open" switch not opening when you latch the top.
If you make and post a video, I can tell you if its the cylinder, bow latch sensor or some other issue.
Old Aug 4, 2025 | 12:56 PM
hross's Avatar
Can't figure out how to upload a MOV on this site. Tired picture but says it can only be 20MB. How do I do it?
Old Aug 4, 2025 | 03:13 PM
Load a video to YouTube and share the link in a post here
Old Aug 4, 2025 | 04:05 PM
hross's Avatar
Okay thanks for your help.
pizzaguy
May 19, 2026 10:48 AM
CyberCG
Jun 9, 2024 02:01 AM
Bargegeek
Aug 29, 2020 08:07 AM
Charlie246810
Mar 1, 2020 04:04 PM
Double L
Jun 11, 2015 11:42 AM
