Central Locking pump/Security Sensor Module
Old Jan 17, 2012 | 04:08 PM
Spooky13's Avatar
Default Central Locking pump/Security Sensor Module
I have a new one for sale for Crossfire or Mercedes Benz SLK $210 (shipping is included). Part # is MB 1708000848, Just PM me for any other info. For the Crossfire this unit locks/unlocks doors, hatch and fuel door and sets security parameters. It is under the foam in the bottom of the rear hatch. They generally sell new for over $400 (dealer $600)...if you can find one. thx
Old Jan 28, 2012 | 04:21 PM
fastfred's Avatar
Default Re: Central Locking pump/Security Sensor Module
pm sent ...thank you fred
Old Feb 1, 2012 | 09:56 AM
Spooky13's Avatar
Fred PM'd you back. vr, Lee
Old Feb 5, 2012 | 06:10 PM
fastfred's Avatar
Pm Sent.......thank You Lee:d
Old Feb 16, 2012 | 12:12 PM
Spooky13's Avatar
Default Re: Central Locking pump/Security Sensor Module SOLD
This item is now SOLD
Old Jan 2, 2016 | 07:15 PM
foxxfire7's Avatar
Unhappy Re: Central Locking pump/Security Sensor Module
Hi Spooky
Do you still have central locking pump module?
In need of one PM me with info
Old Jan 2, 2016 | 08:55 PM
Originally Posted by foxxfire7
Hi Spooky
That last post was nearly four years ago and he said it was sold.
Old Jan 2, 2016 | 11:32 PM
foxxfire7's Avatar
Lightbulb Re: Central Locking pump/Security Sensor Module
Thanks 180
I read that late on his post after I had submitted mine.Would you have any ideal where I could find one cheap?Recently got car.love it.The price of this part is mind blowing.Car going crazy.Starts when it wants.Needs boost that works at times.Seems circuit is open at times,with no door locks.Removed pump,well had water in it.Which I drained.Removed pump allowed to dry ,sprayed and cleaned plugs.No luck..I've read lots of these trends,before joining site where you seemed very knowledgeable and helpful especially with us newbies. .I would appreciate any feed back on this matter.Thanks in advance.
Old Jan 3, 2016 | 04:54 AM
chuK_138's Avatar
The seller has a new account, so I can't say if I would spend the $$$ with them, but he has a used one in stock. 04 08 Chrysler Crossfire Central Locking Vacuum Supply Pump Mercedes SLK 320 | eBay
Old Jan 3, 2016 | 09:41 AM
Thanks 180
If the electrical plugs on the wiring harness going to the pump have been damaged by the water then you must buy the plugs as well, there is not much chance of the pump working if the plugs have bad contacts.
Some suppliers just sell the pump, but others cut the wires and you get the plugs as well. If you just buy the pump and it still fails to work in some capacity you will not know if it is the pump or the plugs. You will have to cut off your old plugs and splice in the new lugs or at least those that are damaged.
This is the eBay site using the part number. CLICK
Last edited by onehundred80; Jan 3, 2016 at 10:07 AM. Reason: Changed the word pimp for pump changes the meaning entirely.
Old Jan 3, 2016 | 04:25 PM
foxxfire7's Avatar
Smile Re: Central Locking pump/Security Sensor Module
Thanks,I will go there now and check it out.
Old Jan 3, 2016 | 05:05 PM
modernuser's Avatar
I replaced my central locking vacuum pump recently, but my alarm won't sound when I try to press the panic button on the key FOB, OR when I lock the car from the inside and open the door; NOR will the exterior lights flash.
I hear a sound coming from the new pump when I try to activate it by locking the car from the inside and opening the door, but no alarm sounds.
Everything else is fine, and the tow light on the dash is finally blinking red.
I also replaced the alarm recently, so I doubt that's the problem.
Any advice? Thanks in advance!
rampntlion
21
Feb 11, 2019 08:18 AM
Mackel
Oct 16, 2015 09:03 AM
xjken
Sep 13, 2015 10:18 PM
bobbie
Sep 12, 2015 12:49 PM
crmnal
Sep 6, 2015 08:07 AM
