Racing The place to talk about autocrossing, road and drag racing.
Stage1 And Intake/thanks Jerry
Old Apr 8, 2011 | 06:37 AM
blackpepper's Avatar
Default Stage1 And Intake/thanks Jerry
My crossfire roadster ran 8.81@une for 83.6mph and 13.50@107.95 stock.I have a twin spectra 3inch intake with my air filters secured in that small compartment with my fog lights,my resonator is off and I got Jerrys stage 1 tune for 175 dollars.I will send my slips in to dragtimes.My first pass was a 8.43@85.35mph an 13.006@109.855 in the 1/4,my 60 ft sucks 2.02.My backup pass was a 2.26 60ft 8.51@85.43 an 13.083@109.926 mph in the 1/4.I'm getting Jerrys stage 2 at the end of the before I get the pulley and the final tune,also I won 25 bucks for the fastest 1/8 mile time of any car driven thru the gates last night at the track and yes it was packed mustangs,camaros ,civics,gtos.Anyone want to take post my slips up here I have them on my cell I can email them or just send them to another member who is good at posting material on this site.
Old Apr 8, 2011 | 10:15 AM
Beaner's Avatar
Default Re: Stage1 And Intake/thanks Jerry
Here are your 3 pics!
Old Apr 8, 2011 | 01:36 PM
Thanks that was quick,I will move up to the stage 2 software and test that at the end of the month.
Old Apr 8, 2011 | 02:42 PM
Beaner's Avatar
looking forward to see the increase in speed! just send me an email and I will post those for you too!
Old Apr 8, 2011 | 09:06 PM
kolevski's Avatar
Hmmm I'd get your car checked out man, it should be running alot faster then that!
Old Apr 8, 2011 | 10:05 PM
Well one issue I have is wheelspin thru first gear and I am 240 pounds plus the roadster is a little on the heavy side
.After I get stage 2 tune I will run a drag radial.
Old Apr 9, 2011 | 12:41 PM
Then again based on your mph and looking at some cars on dragtimes,I think its fare to say that with a e55 intake elbow a crank pulley and some drag radials I should be running your mph.
Old Apr 9, 2011 | 12:50 PM
Theres a member with a code 3 pulley dual 3inch intake with cat delete and they only run 12.6@110 on et streets,my problem right now is traction my mph is good comparing with other crossfires on dragtimes.One other crossfire with a inmotion tune with a intake ran a 12.8 @ 109 even on a drag radial,so I think I 'm doing decent for a roadster on a street tire with just a basic tune and a intake.
Old Apr 9, 2011 | 01:17 PM
32krazy!'s Avatar
take all the factors into account. when i ran a c3 with homemade intake no tune i made a 12.7 pass in november. add a tune and dr.'s and 90* heat in may and could only get a 12.6 weather plays a major role.
Old Apr 9, 2011 | 04:22 PM
I think having my airfilters located in my foglamp compartment helps a great deal and the big killer what I see with other cars and mine is traction there 60ft is 3-4 tenths better if I factor that alone I'll be a easy 12.7.Well I 'm still learning the car but you guys here have paved the way so I take my hat off to every member here.
Old Apr 9, 2011 | 05:08 PM
32krazy!'s Avatar
the smother the flow with the least amount of turns the better the flow. rob proved this with his flow charts. this is a srt-6 correct? if you can get 1.6 or better 60 ft times you will be in low 12 high 11 territory
Apr 28, 2016 02:04 AM
Nov 11, 2015 05:22 AM
Oct 1, 2015 01:42 AM
Sep 25, 2015 02:16 AM
RacerXofFL
Sep 15, 2015 05:00 PM
