fan control module?
Re: fan control module?
Seems this thing is not able to be bypassed then...
Any luck servicing one of these modules to refurb status...? Process...? Anybody...?
I've got the used one on the way... but that's 8-9 days out.
I think I'm gonna hand it off to my guitar tech and let him tear into it. He's an electronics guru deluxe.
Maybe he will come up with something to contribute to the community here.
In this box above the passenger front wheel.
Attachment 40261
50A (Radiator Fan & Traction Control)
Mopar: 05135816AA
05135816AA Mopar NONE FUSE $3.97
FUSE. 50 AMP. Relays, Fuses, Boxes and related items made by Mopar. #05135816AA
Attachment 40261
Mopar: 05135816AA
How did you test the fuse? Did you actually swap the fuses over or test it?
I did the same. I took the fuse box apart, removed all the fuses, cleaned the contacts replaced the fan fuse with a new one, started the engine with the ac on full and the fan started straight away.
on
Is the "Low Coolant" light on? I mean, start car, do you see this on the left side of the dash?
Does the fan work on a hot engine? Maybe I missed the answer to that question as it is an obvious one for someone to ask.
johnnycross413
03-04-2016 04:49 AM
2005 Ragtop
10-03-2015 03:01 PM
