Key Fab doesn't open or close locks
Fuse # 9 blows. can't locate the short. Courtesy light, trunk light doesn't work. Key will open drivers door, but passengers door
will only open from inside handle. Switch on dash will open and close locks and trunk, but only inside the car when doors are closed.
Anything to do with the Body Control Module and if so where is it located? Thanks.
Re: Key Fab doesn't open or close locks
Most likely you have gotten water into the locking pump module, located under the passenger side trunk flooring.
You gotta remove a heap of trim to get to it,
but you can go underneath the car and locate one of the rubber plug things and poke a hole in it to see if water is present.
zombiehunter
03-16-2014 03:55 PM
TVT_DESIGN
06-04-2009 03:44 PM
