removing center console
Old Jul 3, 2006 | 02:23 AM
j-biyzle's Avatar
Default removing center console
my car is not exactly a lego car like my brothers celica. i want to remove the center console so i can do some mods to it. if any one know how to take it out, please post pics and directions. thanks!
jane
Old Jul 3, 2006 | 11:09 AM
Eracer76's Avatar
Default Re: removing center console
I just had the rear part of my console out the other day...
You have to carefully pry up the small trim piece around the shifter, it snaps down, but be careful, pry it up evenly as you go.
Once that is off, then you can pry up the whole piece with the window switches in it, starting from the rear of it, where the crack is. There are two snaps there holding it down and the front tucks in under the ash tray/cig lighter area.
Once that piece is out, there are two screws showing behind the shifter that hold the front of the rear console down and there are two 10mm nuts under the carpet inside the console compartment. Just pull up the carpet at the back of the compartment and you'll see them. After that, pull off the E-brake's rubber cover, it just pulls it straight off with some effort. Then the console is ready to come out
Note: the front of the rear console, were you removed the screws, hooks into the shifter part of the console, so be careful not to break the hooks off when lifting out the rear console.
Hope that helps. Sorry I don't have any pics, I was kind of in a rush installing an Ipod in the console compartment and didn't have my camera handy. The whole job only took about a 1/2 hour.
Old Jul 3, 2006 | 09:57 PM
JCM298's Avatar
j-biyzle,
Check your PM's. Send me your e-mail address and I'll send you a copy of info, with photos from the other forum.
John
Old Jul 3, 2006 | 11:07 PM
upstate's Avatar
I attempted this and it seemed as if the window switch wire was not long enough to allow me to pull the trim piece over the shift handle. Did not want to pull any harder so I gave up.
Old Jul 4, 2006 | 12:35 AM
j-biyzle's Avatar
jane_tan_21@hotmail.com
thanks so much!
-jane
Old Jul 4, 2006 | 08:20 AM
JCM298's Avatar
Instructions sent.
John
Mackel
Oct 16, 2015 09:03 AM
nataliefs
Oct 5, 2015 01:03 PM
55chevy
Sep 13, 2015 07:38 PM
jaesa
Sep 7, 2015 01:50 PM
davidc90
Sep 6, 2015 10:37 PM
