No more traction control, yippy!
Old Aug 25, 2006 | 09:54 PM
dynamicS's Avatar
Smile No more traction control, yippy!
Well I managed to find some time after work, and just pulled the Hydraulic ABS/Traction controller fuse. Drove the car home and absolutely no difference in performance at all!!! Except those momentary pauses when the TC activates is gone! Woohoo!
I can fully rev up to 6,500 rpm before the governor kicks in, so all we need now is for someone with the fused remove to test this on the dyno...
I haven't tested to see If the car will let me drop the clutch yet, but so far it's very stable around corners while in first and second gear under full throttle...
Now all I need is one of those wizbang Supersprint throttle thingy's, lol.
Old Aug 25, 2006 | 10:33 PM
nascarhq's Avatar
Default Re: No more traction control, yippy!
dude! why not just turn it off???
Old Aug 25, 2006 | 10:41 PM
dynamicS's Avatar
dude! you can't turn it off. turning off the TC switch only reduces it's sensitivity by about 20%, so it's always on! and it won't let you drop the clutch even turned off...
Old Aug 26, 2006 | 03:40 AM
HDDP's Avatar
Dynamic. I don't want to burst your bubble. When you pull fuse #5 or #17 + #18 together to disable the TC for a dyno run, the speed sensors in the front wheels which are not turning during dyno runs will cause the car to cut-out @ 5,000 rpm. I've had my TC disabled for quite awhile by removing those fuses altogether, and yes it works when you are driving (or racing in my case), but not for dyno pulls... This whole TC thing that Woody and I have been discussing revolves around getting a full RPM 6,200 dyno run, which as far as we are concerned, is not possible.
I think you missed the posts we made about this issue. To disable the TC remove fuse #5 from the ECU housing, or remove both #17 + #18 fuses from the engine bay fuse box. Both will deactivate the TC.
In order to get a partial dyno run to 5,000 rpm you must remove the TC fuses or the car will just crap-out at about 1,200 rpm. But, this is the key point the engine will DIE at 5,000 rpm on a dyno, whether it be a standard 2 wheel drive or 4 wheel drive dynomometer.
Full RPM dyno's are impossible as far as the experiments we have done thus far.
Old Aug 26, 2006 | 11:12 AM
dynamicS's Avatar
HDDP,
Yes, read most of your post in regards to pulling the fuses for dyno. but I haven't heard of you guys removing the hot lead on the 50 amp TC/ABS hydraulic unit. I was just curious if this would work?
I wasn't really interested in pulling the fuses to disable the TC because it's not easy to turn on/off. I just wanted to test and see what would happen if I removed the hot lead to the 50 Amp fuse for the Hydraulic ABS TC Unit.
My thinking is to install a relay inline with the hydraulic unit's hot lead, so that I can easily switch it on off inside the car.
Old Aug 26, 2006 | 01:53 PM
HDDP's Avatar
HDDP,
I don't know about Woody, but I have not DC'd that hot lead. Anything is worth a try at this point...
Old Sep 13, 2014 | 02:43 PM
lildaddym's Avatar
I'm having difficulty finding the #5 fuse...and the manual isn't clear on which one it is...Looked on page 1673, but there is no fuse 5 listed.
syfi
Mar 28, 2026 04:14 PM
johnnycross413
Mar 4, 2016 04:49 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Billy22Bob
Sep 26, 2015 10:16 PM
