Oil level madness
Old Oct 10, 2006 | 09:28 PM
alipsa's Avatar
Question Oil level madness
I'm new to this place, so bear with me if I don't have the forum etiquette down yet. Can someone help me? Why does my Chrysler dealership insist on adding 8.5 quarts of oil to my '04 Chrysler Crossfire when the manual says 6.1 quarts? At 8.5, the electronic dashboard oil level indicator reads "HI", and the dipstick is wet all the way to the top. When I asked them about this and showed them the manual, they contacted Chrysler and was told that 8.5 is correct. When I later contacted Chrysler, they said that I should ignore the manual, it takes 8.5 quarts. I asked Chrysler what needs to be done to recalibrate the electronic dash oil level indicator so it will read “OK” at 8.5, and not read “HI” at 8.5, and asked them how do I obtain a dipstick that is recalibrated so that I can accurately check my oil level, since it was apparently designed so that 6.1 would be the proper fill level, consistent with the Chrysler car manual. Chrysler tells me to take this up with the dealer. Alldata.com shows the Crossfire as taking 6.1 including filter; Car & driver.com shows the car as taking 8.5. What gives? Am I the only one with this problem? Am I driving the car with 2.5 quarts too much oil?
Old Oct 10, 2006 | 10:18 PM
stryfox's Avatar
Default Re: Oil level madness
The book is wrong.
8.5 is the correct amount for a dry engine.
BUT! if you drain it and replace the filter you only need to put in 8 qt. when changing it.
Old Oct 10, 2006 | 10:29 PM
Hattrick78's Avatar
It is a weird thing, but Stryfox is correct. When I first got my XF, I took it for the first two oil changes to the dealer. Both times they overfilled it. After that second time around, I bought a TopSider oil pump and pumped out ALL of the oil, measured it and it's EXACTLY 8 quarts. Since then I've done four oil changes myself, 8 quarts each time, and it's perfect...go figure.
BTW - You can get the good fleece filters on e-bay for $15 each (including tax and shipping). With the TopSider, you don't even have to get under the car. It takes about 15 minutes to do oil and filter yourself, and costs about $55 to $60, vs. the $120 the dealer charges to overfill your oil!
Old Oct 11, 2006 | 03:04 AM
marauderroy's Avatar
I agree, do it yourself. It's easy and you know it's done with the correct oil and filter. I only put 8 qt's of oil in and it shows full. Just put a floor jack on the drivers side, raise it up enough to slide under and remove 2 bolts (near front) to drop the bottom cover and then remove the drain plug on the pass. side of the oil pan.
Be sure to use a fleece oil filter not the paper ones. Some of the dealerships still have the paper ones in stock and will try to sell you that one. BTW Walmart has the best price on Mobile oil unless you find it on sale someplace.
Old Oct 11, 2006 | 12:48 PM
lukester's Avatar
8 and not a drop more. my 2 cents.
Old Oct 12, 2006 | 01:30 AM
David Burns's Avatar
Your manual is wrong.
The manual that came with my '04, the page that shows fluid capacities is obviously "pasted" in. It says 8.5 qts. I peeled it back, and the page underneath says 6.1 qts.
That said, most people find that only 8 is required to get proper readings from both the electronic and manual dipsticks. Read the other oil level threads on the forum here.
Old Oct 12, 2006 | 09:30 AM
alipsa's Avatar
Thanks everyone for your thoughts. I think I'll try 8 quarts with the next oil change and see if the dipstick and dashboard oil level indicator shows correct amount.
Old Oct 12, 2006 | 10:23 AM
Sennaspirit's Avatar
Since we're on the subject, anyone have recommendations pro/con for Topsider systems? I'm at 7K miles not and it won't be long before I have to do my first change, just wanted to know if there were recommended brands and those to stay away from.
Thanks!
Old Oct 12, 2006 | 12:55 PM
Thanks!
The consensus in the oil threads seems very positive. And it's much simpler than unbolting the guard to get at the oil drain plug. The people that have done comparisons couldn't find a measurable difference in amount of oil removed between a topsider vs. drain plug.
There are old posts with brands mentioned.
Old Oct 12, 2006 | 02:50 PM
Hattrick78's Avatar
Thanks!
The TopSider is the only way to go...no question. It only take a minute or two to get it going and then about another five or ten minutes to suck out all the oil. Just warm the engine for about five minutes before starting. While the oil is being vacuumed out, you have just enough time to change the filer. Easiest oil change I've ever done!
Old Oct 12, 2006 | 04:51 PM
PAULW's Avatar
If you just don't want to DIY check out your local MB dealer. I find their price here in line and they usually know what they are doing.
Old Jun 28, 2024 | 11:49 PM
Wyliecoyote's Avatar
I've just got a new one and on the dipstick it says min at the bottom and max at the top and mine is just passing the max, I love the car but if I had known about this type of thing and the rest of the list I probably wouldn't have bought her, if it's not one thing then it's something else, it definitely sounds like a lot to me but definitely having a stick to read the correct level it's basically down to guess work which is never the best thing to do. Hope you get it sorted out friend best of luck as I need some from someone.
Old Jun 29, 2024 | 10:16 AM
They actually hold 8 quarts. The 2004 manuals were incorrect. It is mechanically a 2003 Mercedes SLK 320. Do not take it to Chrysler.
Old Jun 29, 2024 | 12:31 PM
You are posting in a very OLD thread here 10-10-2006
Member alipsa hasn't been here since: Last Activity: 09-03-2010 04:31 PM
Old Jun 29, 2024 | 03:59 PM
If you do not have one, download the Owners Manual & Service Manual here (FREE) on the website document collection. Read and understand the owners manual, it'll help with many questions you will have. It will be a VERY expensive move if you take your car to a Chrysler Dealership (read a lot of posts here, Chrysler will charge you a lot and may not fix your car) you'll have to research the manuals and if beyond your abilities then look up a reputable Mercedes Benz European mechanic familiar with a 2003 (ish) MB SLK-320. The users manual (and when needed), the service manual can help you understand the car. There are MANY MANY self-help posts also in this free document collection, to help do simple tasks and maintenance on your car. Good luck, many members can help with good reliable information on any trouble you may have.
Old Jul 2, 2024 | 01:28 PM
nickwe21's Avatar
I use a Mityvac to pump out the oil from the top and replace filter. When the Mityvac starts pumping air and I give it a few more pumps, it's usually right or slightly below the 8 quarts mark on the bottle. That is good enough for me. Don't want to take the chance to strip the oil release bolt.
Also, even if a little oil is left over, I do oil changes often so the "old" oil will circulate and be sucked out with the next oil change. It's a simple process, very clean and fast. Takes about 30 mins in total with the longest part being the replacement of the 5 oil filter O-Rings.
But yeah, 8 quarts seems to be the magical number.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
steps
Oct 13, 2015 06:18 PM
Sep 28, 2015 07:40 PM
Billto
Sep 28, 2015 12:05 PM
