Solved a Controversial Subject Yesterday
Old Apr 23, 2008 | 09:38 AM
MMZ_TimeLord's Avatar
Default Re: Solved a Controversial Subject Yesterday
Sounds like I need to rig up a relay for direct 12VDC on that bad boy when I upgrade the Super Charger pulley and IC system.
Thanks for doing the research Steve!!!
Cheers!
Old Apr 23, 2008 | 01:37 PM
Steve Hellums's Avatar
Steve - this is probably one of the best discoveries yet!!
Now you need to wire the IC Pump to a relay and remote fob like you did for your fans. (I think I might just do this) It might be more effective then installing a larger HE.
I would think having the IC coolant flowing through the HE while the fans were running would get you the best results.
All ready did that on post #12 of this thread. Both voltage sources are fused & hot all the time, so the key don't have to be on or even in the car. I can stand several feet away from the car & turn both circuits on and off with one little key fob so the coolant can be circulating and cooled by the fans .
Old Apr 23, 2008 | 02:20 PM
BrianBrave's Avatar
<--- Huge Horsepower
Thanks Steve,
This weekend I am going to run an isolated circuit to the IC pump and have the pump run whenever the the key is on - Sounds like a simple, easy and very effective mod. I know it will lessen the service life of the pump but it's worth the performance gains....Now I just need to decide if I should keep the stock pump installed until it fails or install the Johnson pump on my bench?
Old Apr 23, 2008 | 03:07 PM
Thanks Steve,
I just left the OEM on. If I recall right the OEM pump puts out around 4 gpm and the Johnson is somewhere around 7 gpm. Sometimes more is'nt better, but I really don't know in this case. I was having trouble with my old Stang overheating at highway speeds after putting 3:55's in the rear, at 60 mph it was taching around 2,900. I first thought it was sucking the radiator hose shut, so reinforced hose's well that wasn't it. I replaced the thermostat with a new Auto-Lite, flushed the system and a new radiator cap. I had thought all along it was just pumping the coolant through the radiator to fast for it to cool, I had guy's tell me no way & other's say that's what it was. I put 3:25's in it last fall, now I'm taching 2,600 at 60 mph and she stay's around 180* now. In this case the coolant I believe was being pumped too fast, I wanted to change out the water pump pulley with a bigger one, but it was already close to the crank pulley.
Old Apr 23, 2008 | 03:34 PM
Maxwell's Avatar
yeah I think a faster pump is designed for a horizontaly finned radiator
onehundred80
Aug 6, 2016 12:03 PM
Oct 1, 2015 01:42 AM
Charlesl
Sep 30, 2015 10:46 PM
Abaton6
Sep 24, 2015 10:14 PM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
