Blue fluid leak from behind RF wheel
Old Sep 26, 2009 | 12:47 PM
LugNut's Avatar
Default Re: Blue fluid leak from behind RF wheel
Replaced the tank this morning. Took pics -- will create a "how to" thread sometime/day soon.
Edit/update for future readers: Here's that how-to thread
https://www.crossfireforum.org/forum...ttle-pics.html
Old Jul 6, 2011 | 12:23 PM
chrisdebo's Avatar
I could swear I read a post stating that a hose had come loose, causing the leak. But after taking the fender well apart, the problem was determined to be the same crack mentioned above (where the tank is bolted to the frame).
I don't mean to be one to gripe, but man, this seems to be a stupid problem that could have been easily resolved in manufacturing. I only have 46k miles on my '05. I had the stuck ignition problem a few months ago where the ignition lock and housing had to be replaced. Then the headliner started coming loose and falling down...
Old Jul 6, 2011 | 03:00 PM
LugNut's Avatar
Did my pics/thread, linked to above, help? If so, good!
Old Jul 6, 2011 | 03:04 PM
LugNut's Avatar
Hmmm ... link didn't work, even after editing. Here's another try:
Old Jul 7, 2011 | 01:05 PM
chrisdebo's Avatar
Thanks for the link. Aren't digital pictures awesome! They make understanding so much easier.
BTW, do you think the cracked tank is repairable? It would seem that you would have the same chance of another leak going with a new tank.
Old Jul 7, 2011 | 03:05 PM
LugNut's Avatar
Poyethylene, I'd guess (should be marked), so no. New one from OE Discount wasn't too dear. Note the added fender washer I used to help spread the load.
Old Jul 7, 2011 | 03:19 PM
chrisdebo's Avatar
Good point about the washer. That is exactly where my leak is coming from. What is the washer supporting, the pump?
Old Jul 7, 2011 | 04:36 PM
LugNut's Avatar
No, it's the mounting point for the tank -- it's to spread the tank's weight out more evenly over more area.
Old Jul 7, 2011 | 05:37 PM
PE can be repaired by welding a PE filler rod into the crack with a small blow torch flame. It probably takes a little skill though.
PNA
Nov 12, 2020 04:44 PM
Crossfireconv08
Jul 30, 2015 12:11 PM
Ralph289
Jul 26, 2015 12:52 PM
chturner
Jul 24, 2015 04:47 PM
Romio
Jul 24, 2015 07:03 AM
