Transmission Question
Old Aug 10, 2010 | 03:48 PM
32krazy!'s Avatar
Default Re: Transmission Question
from what i have read the blue tops may be a bit aggresive on downshifting howard. if you want the smoothness your accostomed to this may not be what you are looking for. i think around 250$ for each solenoid.
Old Aug 10, 2010 | 04:48 PM
Since I plan to keep my car for some time, I am sure I will be doing this repair in the future.
thanks for the great info and great pictures guys.
James
Old Aug 10, 2010 | 05:24 PM
tighed1's Avatar
Originally Posted by hcarter
DJ do you have a picture of the back of this unit...?
Just for you!
IMG_1975m.jpg?t=1281475376
Old Aug 10, 2010 | 07:32 PM
hcarter's Avatar
As I thought no reason the screw should just be turning ,,,,,,thanks DJ
Old Aug 10, 2010 | 07:35 PM
DJ, who/what caused the damage in your photo? Just curious.
hcarter's Avatar
THANKS for the heads up Krazy .....you may be right .....
Old Aug 10, 2010 | 07:43 PM
talking to those who have added the blue tops, they drive in winter mode to lesson the effect.....summer mode for bang shiftin'.....not for me right now though....I'm playin' with my rear end first....that sounds a little too much information doesn't it....but, so does LSD.....can't win...starting to sound like Woody....
Old Aug 10, 2010 | 07:48 PM
hcarter's Avatar
LSD AND BANG SHIFTING sOUNDS aLoT lIkE the 70's
Old Aug 10, 2010 | 08:22 PM
MikeR's Avatar
Sounds more like the 60's...... but who's counting???
Old Aug 10, 2010 | 09:36 PM
at least some you old folks get it....lol....
Old Aug 11, 2010 | 01:59 AM
dansrt4's Avatar
So you took your car to them. They stripped the screw. They want you to pay for there screw "no pun" up???
Old Aug 11, 2010 | 07:16 AM
hcarter's Avatar
I can't say that they stripped the screw ,the tech said it was turning but not backing out so they couldn't remove the adapter, I ask them to put it back together and I got my car out of there, the leak is very minimal but any leak bugs the crap out of me , so I will either do it myself of take to a independent transmission shop, we have several good ones in the area so thats where i'm at with the leak .... you live you learn .
Mike your right it was the 60's ,wonder if theres a gasket for leaking memory.....
Howard.
Old Aug 11, 2010 | 08:48 AM
Howard.
It is quite possible that the brass insert that the screw goes into has somehow broken free from the plastic and is turning as the screw is turned. If the screw is just knurled then it may be easy to break the bond, but if it is tapered or somehow keyed in that would be tougher. If the insert is the part that is square at the back as in the picture then I would say it is stripped not loose.
Old Aug 11, 2010 | 09:20 AM
tighed1's Avatar
Someone called "me". Here's what happened.
When doing my connector it would not align so I "helped" it.
Reference the picture above (post 23)
Here is what can go wrong if you provide too much "help" in putting the sleeve in.
The circle on the left is where the pin came out of the slot (just below it). There is another pin on the right side also. Together they hold the connector in place until you "help" too much.
The bottom circle shows where the runs broke when the connector twisted. You can also see where things are shorted on the left side runs. You will know that you did it wrong when you put the car in gear and you are in limp mode.
Old Aug 11, 2010 | 11:48 AM
hcarter's Avatar
I'm leaning more toward the possability that the brass may be turning too ,hoping that with slight pressure pulled against adapter maybe it will back out ,I don't think they attempted to do this because the car was only on the rack a very short time.... ,,,SO HOPE IN ONE HAND CHECK BOOK IN OTHER
Old Sep 27, 2010 | 04:23 PM
robby363's Avatar
I took my car to the dealer today to get the trans connector plug fixed and they had the same problem with the bolt. They have to drop the pan and remove the valve body and replace the piece that's inside the transmission. $764.00 for the part and new filter,fluid and labor. . What away to spend my 3 year anniversary with my XFire.
Old Nov 15, 2010 | 11:56 AM
PNA's Avatar
PNA
Same isssue here. My dealer quoted me $1400 for the part in the transmission. Do you have a part number? I'd like to tell the dealer what it is, what the cost is and then take it somewhere else.
Old Nov 15, 2010 | 12:35 PM
  #38 (permalink)
robby363's Avatar
It sounds like they're trying to charge you for whole valve body which is $1,360.00. You only need the top part of the valve body. I think this is the part# 5097219AA (about $260.00) for your car. My part# was different because it's a SRT. They will also have to replace the fluid and filter.
Old Nov 15, 2010 | 12:54 PM
  #39 (permalink)
PNA's Avatar
PNA
Thanks for your quick reply and the great info. One other follow-up question for you. In your situation, did they have to break off the connector -- and when they broke off the connector did it only affec the top part of the valve body? If that's the case, I expect my situation would be just like yours and I can go back with them with this suggestion.
Thanks again.
Old Nov 15, 2010 | 01:11 PM
  #40 (permalink)
robby363's Avatar
Thanks again.
Yes, they have to break it on the outside so they can remove the the valve body from inside the transmission to replace the top part of the valve body that the connector bolts to.
