SPARE ?
Old Jan 7, 2012 | 07:13 PM
Default Re: SPARE ?
I looked these up on Car-Part.com for the slk320, and all I see is an aluminum compact spare.
Don't know it that would effect the bolt length, and I seriously doubt I could fit this in my roadster trunk with the top down, so probably a moot point for me.
I'll just have to stick with the tow truck.
Default Re: SPARE ?
Originally Posted by steveb8699
I am reporting back for those who are interested. I purchased the inflatable donut spare for a Mercedes SLK 320. Rim Diameter is 15, Rim Width 4.5. Bolt patter 5 on 112. Manufacturer Part Number A1705840538. I attached an image. It turns out the spare fits on the rear, but will not fit over the brake calipers in the front. In other words, it is useless. If anybody has an SLK they need it for let me know. CROSSFIRE OWNERS- THE QUEST CONTINUES!
Good investigative reporting 180. I wonder if steveb8699 has a SRT6 or an NA. That could mean the difference right there.
See post above, I was still searching when you posted.
Old Jan 7, 2012 | 07:14 PM
turbomar's Avatar
Default Re: SPARE ?
I think you have to have shorter wheel bolts as well or the longer threafs hit the parking brake assembly, this is to allow for the difference in the thickness of the steel an alloy rims.
Good point Dave. I recall checking for lug bolt clearance at the rear and the lug bolt comes to about 10mm from the park brake shoe return springs.
Old Jan 7, 2012 | 07:21 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: SPARE ?
Great work 180.
This is the reason that I want to see the size on the inflatable. Also, I found a few today that were 17 inch........so I want to have a good idea before I purchase one.
Old Jan 8, 2012 | 12:08 PM
Crossfireone's Avatar
Default Re: SPARE ?
Sorry Sparkie it took so long to get back to you, was off line for a while. I just chkd. my spare it shows as below:
VREDESTEIN
SPARE MASTER
165/70-16
It fits my 06 n a perfect front & rear. No shims--No diff. bolt lengths required. Hope this helps.
Old Jan 8, 2012 | 01:18 PM
Default Re: SPARE ?
VREDESTEIN
SPARE MASTER
165/70-16
Excellent information....Thank you very much !!
Old Jan 8, 2012 | 02:35 PM
Default Re: SPARE ?
search car-part.com, 'Mercedes SLK', 'wheel w/image', choose '170 Type, SLK230, 16x4-1/2 (alum, spare) ', then look for ones listed for SLK320.
Several listed $75 - $100 ...
Old Jan 8, 2012 | 04:15 PM
Default Re: SPARE ?
Because of the SRT6 calipers, I found some 17 & 18 inch I'm going to look at first.
Old Jan 8, 2012 | 11:13 PM
Kodebuster's Avatar
Default Re: SPARE ?
A few months back I Drive 1200+ miles to Florida from NY.
Car runs great, tires perform better than expected on arrival.
Pull out of the driveway next day for a local cruise with the top down, and hear that telltale ticking sound coming from the rear driver side.
Hopng it was a rock caught in the thread, but it turned out to be a sheet metal screw.
A spare alway interested me cause I'll be making that 1200 mile trip a few times a year, but the Roadster poses an impossible situation, even with the top up.
Even if I could fit a donut in the trunk, what would one do with the regular sized wheel that just came off. The passenger seat is not an option if someone is sitting in it.
I check the tires religiously, and have learned to live with no spare.
(And NYC streets are like going 4 wheeling on a good day...LOL...)
Old Jan 9, 2012 | 07:23 AM
Default Re: SPARE ?
You know, I was actually considering getting one of those collapsible donuts until I read kodebuster's comment :
I hadn't even thought if that. I am not about to leave a $200 wheel and $200 tire on the roadside, so I guess that spare idea is not workable for me and my roadster.
Guess I could always do what BLACKSRT-6 did and put a trailer hitch on along with a trailer designed for a motorcycle and put a 19", an 18" and a spare trailer tire in that.
NOT !!!
( he uses his to carry his autocross wheels/tires to the races, so for him it makes sense )
Old Nov 4, 2013 | 03:46 PM
Tony Palmer's Avatar
Default Re: SPARE ?
Hi J,
Do you know if the lug pattern is the same for both the 18" front and 19" wheels? If so, is there a mini spare that could be used for front and back?
Thanks,
Tony Palmer
Durango
Old Nov 4, 2013 | 04:20 PM
Default Re: SPARE ?
Originally Posted by Tony Palmer
Hi J,
Thanks,
Tony Palmer
Durango
See post # 25 in this thread.
Old Nov 4, 2013 | 04:28 PM
ZX2 Nick's Avatar
Default Re: SPARE ?
You can't be serious can you? They said the lug pattern was different? You believed them?
Do you have a brain? Both cars use exactly the same components underneath.
If you get yourself an SLK 230 (not 320) spare it will work as a spare just fine.
Originally Posted by j monaco
I previously posted a question regarding a compact tire or doughnut for the Crossfire. I spoke to the dealership and asked if the spare from the SLK would work with the Crossfire. I was informed that the lug pattern is different and therefore not the solution.Dealership said they checked with home office.
Does anyone know if there is an after market product available? i'm concerned with getting a blow out and being stranded.I know towing is available but thats no solution and the repair kit is not going to help.
looking forward to hear from our technicians and informed members as to what they are doing.
j monaco
TerryR
Dec 13, 2019 03:27 PM
MiamiTVR
Jan 30, 2016 02:15 PM
o55ie18
Oct 5, 2015 05:50 PM
Dgiomatch1
Sep 20, 2015 01:05 AM
RacerXofFL
Sep 15, 2015 05:00 PM
