Engine Oil Change
Old Sep 23, 2011 | 04:37 PM
mrjazzmillcreek's Avatar
Default Engine Oil Change
As the recent owner of a 11,000 mile Xfire Coupe that had the oil changed at time of purchase with Mobil 1,how often should I change it when the car will not likely be driven more 200 miles per year ???
Old Sep 23, 2011 | 04:54 PM
texas t's Avatar
Smile Re: Engine Oil Change
NEED TO DRIVE IT MORE THAN THAT,I IF DROVE 200 MILES A YEAR I WOULD jUST HAVE THE OIL TESTED MAY LAST SEVERAL YEARS
Old Sep 23, 2011 | 05:06 PM
killerkanadian's Avatar
Default Re: Engine Oil Change
Just change it once a year.
Old Sep 23, 2011 | 07:04 PM
05roadsterguy's Avatar
Whats Up Bro? Yea its Me! Most Garage Queens get 1 oil change a Year. ( same with the Fuel! ) I drive mine like I stole It and do the 3000 regularly. Though the spec for M112's is 5,000 miles
Old Sep 23, 2011 | 07:56 PM
Why would someone buy a Crossfire to drive 200 miles a year? Have you noticed the track record for resale value?
Life it too short, drive the dang thing and enjoy it!
James
Old Sep 23, 2011 | 08:37 PM
KimPossible's Avatar
I don't drive mine a ton but the oil is changed once a year whether it needs it or not. I hope you are using some type of fuel stabilizer too. I really don't drive my roadster a lot in the summer because of the heat here in FL. I have to use Stabil to keep the gas good and clean.
Old Sep 23, 2011 | 09:39 PM
I have another Xfire,a yellow roadster that I do drive,the red coupe may not be driven at all.
Old Sep 23, 2011 | 09:54 PM
itsky's Avatar
Certainly change the oil once per year. If you are going to only drive it 200 miles a year, put some fuel stabilizer in the tank to prevent the fuel from rotting out your fuel system or at least drive it 50 miles a month to "blow out the cobs".
Old Sep 24, 2011 | 12:08 AM
Good call, i would opt to fill the gas tank up and stabilize it with a can of seafoam instead of just sta-bil.
Old Sep 24, 2011 | 08:55 AM
TiredRetired's Avatar
Seafoam???
Old Sep 24, 2011 | 10:07 AM
Originally Posted by TiredRetired
Seafoam???
Yea, Advance has it. Seems to be genuine snake-oil for engines, be they gasoline or diesel :
"Sea Foam� Motor Treatment for Gas and Diesel Engines is a 100% pure petroleum product that works instantly to clean deposits from internal engine parts and remove moisture from oil crankcases and fuel tanks. As a fuel system additive, Sea Foam� will clean carburetors, fuel injectors, clean carbon, gum and varnish deposits, add lubricity to fuel, stabilize fuel and control moisture. As an oil system additive, Sea Foam� controls moisture, gum, varnish and residue deposits"
and all for only $6.99 !!!!
( I like the 'lubricity' part, rekon if my gas is lubricated, should flow better )
Old Sep 24, 2011 | 02:16 PM
Well, you learn something every day. Gonna check it out! Thank you!
Old Sep 24, 2011 | 02:20 PM
I noted that it worked as a good fuel stabilizer when i was reading about cleaning out the injectors in my friends dodge cummins by pouring it straight down the throttle body.
But i figure if your fuel is sitting that long, you might as well get a cleaner in there as well as a fuel stabilizer. Although i don't know how the rest of these forums feel about fuel additives.
Ralph289
Sep 12, 2021 11:15 AM
PNA
Nov 12, 2020 04:44 PM
xfClifford
Aug 3, 2015 11:03 PM
Crossfireconv08
Jul 30, 2015 12:11 PM
skeet370
Jul 18, 2015 01:02 PM
