so to upgrade the ECM you have to replace the chip?
This is a question more of curiousity than anything....
Most of the cars now days the ecm can be flashed to reprogram the AFR or the shift points, cooling fans, timing etc.
Is there a reason the complete chip has to be removed vice just flashing the eeprom? Or is it nothing has been developed yet to do so?
Thanks!
mo
Thanks!
mo
Searching helps sometimes.
Go here: https://www.crossfireforum.org/forum...pic.php?t=2159
and look down for the entry that starts: Upsolute Today: Part 2
Sea,
I did search and read the very same link
thus the reason for my question...
Everything have seen suggests that the ECU has to be pulled and the Eeprom removed...
The other two cars I have can be programmed through the ODBII connector, this i think is tremendously easier than soldering and desoldering chips...
aside from the programming "modification" I have the wherewithall to do the same thing myself I have the prom burners and such
So based on your answer, there is no alternatives aside from soldering and desoldering the chip...
Mo
Mo
Mo
Mo
Originally Posted by WMichaels
The prom does have to be removed and reprogrammed. None of the performance chip companies are offering any chip tuning via the ODBII port.
And if the circuit board wasn't designed to allow in-place flashing, the only way to properly isolate the chip for reprogramming is to remove it.
axnguyen
Jul 21, 2015 11:41 AM
