Mis fire all cylinders
Old Jan 28, 2014 | 10:03 PM
cfree's Avatar
Default Re: Mis fire all cylinders
Originally Posted by sk8erjosh09
You are in Vegas? I will be there February 13th around 8-9pm. I'll have my star diagnostics system with me if you would like to get together. If none of those changed the issue then I'm at a loss. Have you checked your RCM?
Would the RCM be throwing its own code? When reading codes it randomly goes from cylinder to cylinder but the only codes are cylinder mis fire. I ruled out coil packs since its random and all cylinders. Is that a mistake? Also plugs and wires for the same reason. I feel it must be something simple I am over looking. I read the post on rcm repair and will be contacting tighed1 this week. Seems like a good idea even if not my current problem. Thanks for any input and help.
Old Jan 29, 2014 | 10:29 AM
sk8erjosh09's Avatar
The RCM wouldn't throw it's own code, it is just a Relay Gateway, or housing if you will. The relay's are for things like the fuel pump, air pump, traction control etc.. We've heard all kinds of weird stories from the contacts or relays going bad. If the contacts are on there way to going bad for the fuel pump, it wouldn't surprise me if it was misfiring. Has it ever not cranked? Where all the lights are on, and the key does nothing? Or has it ever died on you while driving down the road?
Old Jan 29, 2014 | 03:33 PM
cfree's Avatar
It starts and runs. Obvious misfire while driving. Has not died while driving. About 6 months ago my daughter was driving and she said it wouldn't crank. I went to check it out and it started right up, no code. This problem started about a month ago. Hard to start and misfire. Once warm I could turn off and back on it would run fine. Next day I had had codes checked and reset computer. No problem for a week. Then same thing and won't clear up after restart.
Old Jan 29, 2014 | 03:59 PM
Default
That's your RCM man.
Old Jan 29, 2014 | 04:10 PM
cfree's Avatar
So pull and send to tighed1? I assume he still does fixes. Saw a post last month. Easy to do?
Also see a post here for Airtex for about $140. Any updates on them and if its a good replacement?
roar
Jun 15, 2022 11:46 AM
miscetera
Oct 5, 2015 11:40 AM
Charlesl
Sep 30, 2015 10:46 PM
atdavis2
Sep 21, 2015 01:25 PM
