ESP/BAS, ABS and CEL lights
Old Feb 9, 2014 | 07:08 PM
Default Re: ESP/BAS, ABS and CEL lights
Dunno - just found that on the web.
I do have the AllData for my '02 Concorde Limited, but it's a 3.5.
Is your 300 a 3.5 v6, or a Hemi ?
( 300C might mean it's a V8, I don't know 300 stuff )
It's a 3.5 V6, none of this 4 cylinder stuff for me. I'd like a V8 though.
Old Feb 9, 2014 | 07:17 PM
velociabstract's Avatar
Since you've had brake problems, rusting up etc. I'd clean the sensors before going any further.
Les
Old Feb 9, 2014 | 07:34 PM
Les
That is a good point, I'll have to take it in. It's too cold and I'm to old to F around on the driveway.
Strange no codes though. Thank you and everyone else for their help.
I'll report back.
Old Feb 10, 2014 | 06:54 AM
Dave, I spent about an hour going through the AllData on your issues : NOTHING !
I doesn't even list your code, and while it does mention short/long runner. that's about it.
AllData pretty much sucks, for the most part.
Old Feb 10, 2014 | 09:25 AM
Thank you for that effort, I really appreciate it. I have tried searching but all I came across was what I posted earlier;
When Monitored: With the engine run time above a calibrated value, battery voltage greater than 10.4 volts, ECT within a specific range, and the Short Runner Valve Assembly (SRV) control active.
Set Condition: The Powertrain Control Module (PCM) compares the circuit feedback to a calibrated closed range, between 75% & 85% Pulse Width Modulated (PWM) duty cycle, when the circuit is de-energized or to a calibrated open range, between 35% & 55% PWM duty cycle, when the circuit is energized. If the value is determined to be out of the calibrated range in either the de-energized, greater than 85% duty cycle or less than 75% duty cycle, or energized, greater than 55% duty cycle or less than 35% duty cycle, state for more than a calibrated amount of time, this DTC will set.
That means nothing to me sadly. I would not know a pulse width modulated cycle even if I could ride it.
I got % readings outside of what they say but it is called something different, I am guessing it means the same. So I have ordered a new part.
Meanwhile on the other problem I am still looking.
I have been offered assistance and the use of a garage by my good friend SparkieSRT6 and I am going to take advantage of his offer. If I have to take this into a stealer or something in the end I would like to know what I am up against. Forewarned is forearmed as they say.
Old Feb 10, 2014 | 02:37 PM
I thought that I had a breakthrough here, not to be though.
I had read that the codes could be read by playing with the iggy key, ON > ACC > ON > ACC > On.
All of this in 3 seconds, I had done it before with no luck, Well I did it again and it worked.
Codes P1004 AND P0645 showed up in the odometer window.
Turns out that P0645 is; Air Conditioning (A/C) Clutch Relay Control Circuit.
Hopefully that's why the AC quit last fall.
Still no code for the BAS/ESP and ABS.
Old Feb 10, 2014 | 10:49 PM
I was showing a buddy the key dance tonight, ON, ACC, ON, ACC, ON and the P1004, P0645 codes came up.
There was a ding noise and another code came up U1417 which is Left front wheel sensor fault.
This did not show up on my hand held scanner or his.
Now we have; wheel sensor, AC clutch relay and short runner solenoid faults to fix.
I am a happy man. Finally something definite to fix on the ABS, ESP/BAS fault, well maybe.
Old Feb 11, 2014 | 07:09 AM
Keep smiling through, just like you always do ....
Till the blue skies chase the dark clouds far away ....
Good to see you happy !
Old Feb 11, 2014 | 07:43 AM
As you know, the worst/frustrating part is not being able to find the cause of the problem. Now peace and tranquillity have be re established. Let us know how the repairs go.
Les
Old Feb 11, 2014 | 08:13 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
So are you bringing it up here with the new parts in hand.?? Sunday is looking great for me.
T'stat will be set to 70, lots of tools....if I can find them all. Did I tell you my wife sells for a brewery......
You may need a ride home.
Old Feb 11, 2014 | 09:24 AM
I will have some parts, I'll bring my tools as well.
Sunday is fine with me.
The Chrysler 300 has the best scanner, my Innova 3100 and UltraGauge can only find the P1004 problem. That really sucks.
Old Feb 11, 2014 | 08:34 PM
bjames's Avatar
Amazing, I have answered lots of questions and nobody can answer a question for me.
I would have answered if I had something constructive to say, but I didn't. So I couldn't help you, so that's why I didn't answer, but I certainly would have if I had any information. Good luck
Old Feb 12, 2014 | 10:16 AM
Originally Posted by RED DOG
I think you'll find that the systems are actually working even though the three trouble lights are on. The lights should go out by themselves after a half dozen or so cycles of running the car. Be patient. When you go in for your testing there will NOT be any trouble codes stored in the computer related to this issue.
When I took the car around the block after playing with the reader, disconnecting the battery etc all systems were definitely off. I have driven the car some 60 miles since and the system now appears to be partially working. The lights do remain on though. Throwing the car around and slamming on the brakes was hairy on the snow bank narrowed roads but fun before, now it has gone almost back to normal. ABS does not work, nor the cruise control. The ESP does appear to work a bit though. They say you cannot manually fully disable the systems so possibly it keeps whatever it can going when there is trouble.
As I said before the 300's built in code reader is better than my Innova 3100 and the UltraGauge. It picked up two codes the others missed the AC and front left wheel speed sensor errors. I guess it stands to reason that if the car knows something specifically is wrong it should be able to spit out the reason.
Old Feb 12, 2014 | 06:14 PM
RED DOG's Avatar
Hi Dave, Glad to hear you're making some progress. How exactly do you get the 300's internal system to display the trouble codes. I have a wheel speed sensor issue that is intermittent and sets off the three trouble lights but my code reader does not pick up a trouble code. Can you explain the procedure?
Old Feb 12, 2014 | 06:36 PM
I Googled this :
Code retrieval can be accessed by the ignition key or by a diagnostic readout box(DRB).To obtain the codes using the key method,set the park brake,and put the vehicle in Park/neutral.
Some 95 and later OBDII vehicles, you may be able to retrieve OBDII codes with this procedure, if equipped with digital dash.
Turn the ignition key ON,OFF,ON,OFF,and finally ON again(ENGINE NOT RUNNING)
The codes will start to flash on the POWER LOSS or CHECK ENGINE light.
FLASH,pause,FLASH,FLASH=code 12
Old Feb 12, 2014 | 06:59 PM
RED DOG's Avatar
I think that might be MORSE code
Old Feb 12, 2014 | 08:08 PM
I Googled this :
That is some cars, my 300 was different.
With the key in the ignition in the OFF position, car off naturally.
Turn to ON, (after that point the starter will kick in).
Back to ACC. (Not to OFF)
Back to On.
Back to ACC.
Finally back to ON.
The codes will show up one after the other in the Mileage LCD window.
It shows the actual code, P1004, P0421, U765 etc.
Get ready to write them down.
When they have finished the LCD will say 'dOne' (Odd size characters)
It works best I find by starting from the OFF position. I get it to work every time now.
Old Feb 13, 2014 | 04:54 PM
  #38 (permalink)
RED DOG's Avatar
Back to On.
Back to ACC.
Finally back to ON.
THANKS for the info (and for the PM). As soon as I can get into that particular SRT8 again I'll try to get it to display a code. I'll let you know if it worked for me.
Old Feb 13, 2014 | 05:16 PM
  #39 (permalink)
I have dealt with a lot of error codes, SIDS, PIDS, etc with my International tractor. A lot of times it is corrosion built up in the connectors causing just enough resistance in the line and affect the voltage to make it display a trouble code. Cleaning some of the connectors associated with whatever is throwing the codes might help. May be corrosion in the wiring as well, which is hard to find without a meter. Good look. I know these codes are a pita to run down.
Old Feb 13, 2014 | 06:53 PM
  #40 (permalink)
Limited success, after freeing up the short runner valve with carburetor cleaner, the code has been erased and the CEL light is OFF. I think that the system needed 'x' number of miles under its belt with a number of self checks done by the computer to convince itself that all was well. HOORAY for that.
I have a $150 plus shipping solenoid on its way by courier from the states that is not needed. Can't win them all I guess.
The AC code P0645 is there still but it does not light up the CEL. As the car would be lighter on gas with no AC the system fault does not initiate the CEL.
I am left with the ESP/BAS and ABS lights to eliminate.
I did install a new battery, amazingly the OEM battery did not have handles, although it had provision for them. Saving pennies is being taken to the extreme if that is the case.
Doc, I pulled the connector to the frame harness and it was all nice and clean.
