Can I replace the spoiler button with a toggle switch?
Old Aug 11, 2014 | 10:38 AM
Freezer's Avatar
Default Can I replace the spoiler button with a toggle switch?
For aesthetic reasons, I want to disable the spoiler switch in my crossfire coupé 04. Then I want to reroute the wiring to a new switch closer to the driver. This is what I want the new switch to look like:
*I'm thinking of placing it under my ignition switch.*
My concerns is because the stock switch is a push and hold type this may not work.
But by changing to a toggle switch I may be able to stop the push and hold setup, and have the spoiler react fine when the switch is toggled. I'm going to guess this will work fine, but being toggled that means the motor is always on, right? Could this hurt the car? And is it even possible? Has anyone else tried or done it?
Old Aug 11, 2014 | 11:08 AM
Default Re: Can I replace the spoiler button with a toggle switch?
Switching the spoiler is not in the conventional way. The switch does nothing more than sends a signal to the BCM. See the attachment.
Sending full voltage back to the BCM signals it go in one direction. Sending reduced voltage back to the BCM signals it to go in the opposite direction.
Old Aug 11, 2014 | 11:13 AM
Freezer's Avatar
Sending full voltage back to the BCM signals it go in one direction. Sending partial voltage signals it to go in the opposite direction.
[IMG]https://www.crossfireforum.org/forum/attachment.php?attachmentid=32739&stc=1&d=14077695 59
So I will fine by doing this? I don't quite understand schematics.
Old Aug 11, 2014 | 11:19 AM
I am not going to say either way. I don't quite understand what you are trying do or how you plan to wire it. Maybe someone else can help out here.
Old Aug 11, 2014 | 05:26 PM
Toolman's Avatar
I don't understand how disabling the "manual" spoiler switch is an aesthetic reason. The switch will still be there. The schematic shows the existing switch has a resistor inside it to vary the voltage to the Body Control Module. No other aftermarket switch is going to work unless you know the value of that resistor and add it to the new switch. In addition, the new switch would also have to be "momentary contact" like the original.
Old Aug 11, 2014 | 05:53 PM
Freezer's Avatar
The idea was to make a better looking switch for the "cool" factor more than anything. I was going 2 leave the stock switch as a dummy then drill and place the security switch (red cover) just for looks and also for actual use. But it doesnt really matter. I think i have an idea of what i want to do anyways.
Hoppy
Dec 7, 2018 07:36 AM
northwest_crossfire
May 30, 2016 05:19 PM
srtmodder
Jul 29, 2015 05:12 PM
gtjl
17
Jul 22, 2015 06:28 PM
66L72M21
Jul 15, 2015 04:23 PM
