stumbling
Old Sep 29, 2014 | 02:20 PM
johnnycross413's Avatar
Default stumbling
I have a 04 na xfire
As of lately the cars has been stumbling when you step on it from a stop or under hard acceleration
All new plugs
Checked for vaccum leaks
Any ideas? im thinkin maf sensor
Old Oct 1, 2014 | 09:48 AM
robby363's Avatar
Default Re: stumbling
Have you changed the fuel filter?
Old Oct 1, 2014 | 06:58 PM
No, think that might be the prob
Old Oct 2, 2014 | 06:35 AM
ncarter's Avatar
Johnny, I`m having the same issue in first gear...I was thinking it was electronic related..but the fuel filter could be a cheap fix...I`m gonna try it & keep my fingers crossed...who knows ?
Old Oct 2, 2014 | 10:01 AM
Now that u said electrical, im going to double check. I know i have the light icon on the dash that occasionally turns my traction control off. Im going to fix my bulbs to see if it fixes it
Old Oct 8, 2014 | 01:14 AM
I still get the light bulb but all my lights are working. Car stumbles like a missfire still, and today it stalled out.
Brought new fuel filter installing it friday. And checked for vaccum leaks
New spark plugs pre gapped
Checked vac leaks
No check engine lights
Crank sensor?
Maf sensor?
Old Oct 8, 2014 | 03:02 AM
ncarter's Avatar
Johnny, I added a bottle of injector cleaner & did a throttle reset..then drove it "like I stole it".:. Seamed to do the trick for me. Good luck, Neal
Old Oct 8, 2014 | 03:17 AM
Put injector cleaner but didnt try the reset will give that a shot
Old Oct 8, 2014 | 01:03 PM
RL67037's Avatar
Checked vac leaks
Crank sensor?
Maf sensor?
Have you checked your license plate lights (there are two)? Those are normally missed when checking all of the lights.
Old Oct 11, 2014 | 03:47 AM
Got the light off, it was a brake light that wasnt plugged in right
Then had my fuel filter changed, helped a little with the stumbling. Now it only stumbles until the car warms up
The mech told me it might need bigger injectors because it has cai 74mm throttle body & maf housing with baffles gutted and screens removed and tuned
Old Oct 11, 2014 | 06:43 PM
do the throttle reset and then go drive it hard. see if it recalibrates the throttle control.
Old Nov 14, 2014 | 03:06 AM
Changed the fuel filter and crank sensor. Car runs but while you drive itll jus shuts of, And power cuts off at 3k. I have the spark plugs changed about 4 months ago. Im lost as what the problem might be and theres no light or codes to b read
Old Nov 14, 2014 | 10:56 AM
Sounds like it could be bad connections in the RCM.
Old Nov 14, 2014 | 06:40 PM
if you have changed the cps and it is shutting down, then I have to agree, time to check out the RCM.... two things can cut power, the CPS and RCM.... A bad coil would create a misfire, or rough idle.... Since you have gutted the maf, that could be some of the idle/accel problems as well....good luck
Old Nov 15, 2014 | 08:41 AM
zip439's Avatar
I have just completed the RCM swap with "tithed1" fast and easy, painless. Check out the TBS stickies for RCM repair.
Old Nov 17, 2014 | 02:01 PM
Jus checked my rcm, had bad solders. Getting it fixed hope this is the prob.
thanks for the info, i kno the dealer would of raped me
Snake Eyes
Sep 28, 2015 08:55 PM
RyanB
Aug 6, 2015 07:24 PM
kevtamus
Sep 15, 2010 12:58 PM
SparkieSRT6
Aug 30, 2010 05:58 PM
Maxwell
16
Dec 17, 2007 12:44 PM
