convertible top problem
Old Feb 13, 2015 | 05:08 PM
parisfitt's Avatar
Exclamation convertible top problem
Anyone. no why u have to wait 30second till u can fully let down the top after u push the Covert down is anybody else having this problem that got it fixed what should i do
Old Feb 13, 2015 | 06:08 PM
Default Re: covertable top problem
Is the top taking 30 seconds to go down completely from the point were you have unlatched, raised the front, then press the top down switch ?
( not sure I understand what is happening )
Old Feb 13, 2015 | 07:08 PM
parisfitt's Avatar
I pull. the. emergency brake. up then unlatch the top. the Windows go down then i push the switch down wait until i hear a beep then i. let go for 30second. then. i hold the switch down for it to open. sometime it works fine . ps i have no problem closing it
Old Feb 14, 2015 | 12:32 AM
Just guessing, I'd say maybe a problem with the pump building up pressure.
See any hydraulic fluid leaks around any of the 5 cylinders ?
Check the fluid level in the pump reservoir .
How long between when you first push the 'down' switch and you hear the beep ?
Old Feb 14, 2015 | 01:45 PM
parisfitt's Avatar
Hi thanks for replying. well i hear the beep soon as i push down the switch. but then i have to wait 30seconds after i push down the switch. After 30seconds is up i hold the switch down until the top is down. If it dont go down right then i hear a beep noise. so i turn off the car an start over
Old Feb 14, 2015 | 01:54 PM
Mrmiata's Avatar
This sounds like you just push and let go after it beeps.. then have to wait 30 seconds and push and hold it. You realize you push and hold down till top is in place and beeps to "let go".. right?
Old Feb 14, 2015 | 01:59 PM
Unless a prior owner installed the "one touch" top mod.
Old Feb 14, 2015 | 02:02 PM
Mrmiata's Avatar
My after thoughts also.. since he states just pushes the button and it goes up..
Old Feb 16, 2015 | 12:42 PM
AlG's Avatar
AlG
Default Re: convertible top problem
I have this same problem on my 05. Sometimes the top goes down on the first button push sometimes not. But I put the top down a lot in warmer weather and can cycle it two or three times a day. I've learned to live with it.
ZERACER
Jul 7, 2020 10:21 PM
Hoppy
Dec 7, 2018 07:36 AM
PimpDaddy
Sep 29, 2016 11:55 PM
mike28117
Jul 17, 2015 01:59 PM
Bayukbros
Jul 17, 2015 11:21 AM
