Srt Turns over but does not run
Old Mar 23, 2015 | 12:39 AM
Cerda-fied's Avatar
Exclamation Srt Turns over but does not run
Hello,
I was having battery issues last month and finally replaced the battery. Turned on a little rough and idled fine for a few minutes as i was cleaning up tools. Then it shut off and would not turn back on after trying a few times. Then tried to read codes and none were found. Checked RCM and all solder looked great but did three trouble areas just in case. Still not wanting to start up. Where do I go from here? Does crankshaft position sensor give trouble codes when bad?
Thanks,
Old Mar 23, 2015 | 08:01 AM
Default Re: Srt Turns over but does not run
Does
mean :
1. the engine turns over but does not start
2. nothing happens when I turn the key
If #1, then yes, could be the CPS, get a Bosch and replace it. ( could also be fuel related )
If #2, still could be the RCM, except in this case relay contact or relay coil issues. ( send RCM to tighed1 )
Old Mar 23, 2015 | 08:29 PM
Cerda-fied's Avatar
I am going to order a cps on Amazon they seem to have the best price on a Bosch one. Thanks. Also, started looking on here for other issues I started having. After a few lock unlock cycles the locks quit working. Pulled the drain plug out of the bottom of truck and drained about a gallon out of water from pump side other side is perfectly dry. We have had lots of rain on east Texas.
Old Mar 24, 2015 | 07:09 AM
That didn't answer my question, but yes by all means keep the pump dry.
Old Mar 24, 2015 | 09:11 AM
Lots of rain or a little rain, when it leaks it leaks. Fix the leak before getting a new pump. They cost $300 or so used and $600or so new.
Old Mar 24, 2015 | 02:55 PM
Cerda-fied's Avatar
[QUOTE=ala_xfire;830841]Does mean :
Sorry #1. Starter turns engine over like normal but does not start.
Also, lots of rain and water. Pulled foam out and pulled plug to drain at least a gallon. Working on drying up inside of pump. Lower inch was in water. Three pins on on the lower connector are gone. I will try and resolder new pins and other corroded components. Prices to replace are 250-600. Now to try and find the leak. Could this be causing the starting issue?
Old Mar 24, 2015 | 04:07 PM
tighed1's Avatar
Have seen more and more fuel pump relay coils going bad.
Can you hear the fuel pump energize for a couple of seconds when you turn the key to the on position?
If not could be the fuel relay.
To test if the fuel relay is bad, Open the RCM and close the contact on the fuel relay (#4, see picture). If car starts and runs, Ta-da! You found the problem.
I can fix that for ya. :-)
Another way to check w/o opening the RCM------
Shoot Carb cleaner (something flammable) into throttle body and see if car runs as long as you are spraying. If it stops when you stop spraying. Good chance it's the fuel relay.
Old Mar 24, 2015 | 06:33 PM
Cerda-fied's Avatar
So I was turning the car over to check if I could hear anything with the relay and it started right up and ran. Left it idle again and it died after a minute or so. I can hear a loud click of a relay in the RCM when I turn it to run and a pump sound under the hood close to the transmission area. When I press on the fuel rail test port it always shoots a little fuel out. I'm still thinking crankshaft sensor. I read it can fail as engine warms up. How are you holding the relay closed? Alligator clip?
Old Mar 24, 2015 | 07:07 PM
texas t's Avatar
replaced cps on srt6 today 64000 miles
Old Mar 25, 2015 | 12:36 AM
tighed1's Avatar
Human finger. Assistant starts car.
Something like a match stick or the like will work.
Old Mar 31, 2015 | 10:11 PM
Cerda-fied's Avatar
After ordering crankshaft sensor and installing with no luck I had a friend come over to crank the car while I held down the relay. Worked and started up great. Pulled RCM and used 12v power supply to test relay coils directly all worked except fuel pump. Should have done those to begin with. O well.
Old Apr 1, 2015 | 09:15 AM
tighed1's Avatar
Send RCM for repair to:
DJ Tighe
3601 Pinnacle Ct
Sierra Vista, Az 85650
$25 gets the RCM tested, both fuel pump and air pump relays replaced, Me So Horny mod applied.
I then test it in my car then return to you via USPS Priority Mail. Usually repair the day I receive it and have it back in the mail the next morning.
I gotta start charging more for this!
dj
Old Apr 1, 2015 | 03:00 PM
DJ Tighe
3601 Pinnacle Ct
dj
YES ! If you are replacing 2 relays, you should. That is not a trivial task, been there, done that and ain't going back again.
Old Apr 1, 2015 | 06:09 PM
Cerda-fied's Avatar
Tighed1
PM me with the best way to pay you. Then I'll send it right over. I appreciate the help. Thanks so much.
Old Apr 1, 2015 | 06:36 PM
Most people just put the $25 cash in the padded envelope with the RCM.
Be sure to include your return address.
( I know, because I did these repairs for people back when DJ went walkabout for a few months , but he's a whole bunch better at it than me !)
Old Apr 2, 2015 | 09:07 AM
tighed1's Avatar
Yeah. What he said!
Old Apr 6, 2015 | 04:45 PM
Cerda-fied's Avatar
Yeah. What he said!
Shipped out today on your way Tighed1. Included extra envelope with return shipping paid and all labels ready to ship back. Thanks
Old Apr 7, 2015 | 05:09 PM
Post title reminds me of training a pet to 'roll over and bark'... LOL
4drturbo
Jan 3, 2019 02:46 PM
tom2112
Oct 26, 2015 08:18 PM
tom2112
Jul 28, 2015 08:12 AM
leaddog2015
Jul 13, 2015 12:25 PM
tom2112
Jul 12, 2015 04:41 PM
