Does this sound right re Autobox Torque Convertor
Old Mar 23, 2015 | 12:49 AM
Bay Cruise's Avatar
Default Does this sound right re Autobox Torque Convertor
Auto Box Torque Convertor slip (sound like going over a cattle grid) between 50-60KPH very occasionally when changing up in humid weather. Lasts for about a second.
Just been to see my auto box mechanic again and he says these gearboxes do do this and he would not do anything as it can go away. If the convertor or solenoid packs up you will know and that’s the time to repair it.
Does this sound right ??
Old Mar 23, 2015 | 01:38 AM
syfi's Avatar
Default Re: Does this sound right re Autobox Torque Convertor
The W5A580 is extremely sensitive to the quality of the transmissions fluid. Even with the slightest hint of water in the fluid (as low as 0.05%) the transmission can start shuddering. If you experience shuddering with your transmission, try changing out the fluid with new fluid and be sure to replace the internal filter, too.
http://www.allpar.com/mopar/transmis...AG1-WA580.html
Old Mar 23, 2015 | 01:46 AM
Bay Cruise's Avatar
Thanks syfi, the fluid was changed only 2-3 months ago with the filter when my 722.6 plate was replaced. The plug was also changed, but it did leak 3 weeks later from the new plug so he fitted new seals again and all been good for the last 4--5 weeks. Seems that this is common with these o rings, even new ones !!. No leak now all dry. I did get him to check the old level again this morning and it was all ok and clean as it should be. What you say syfi does now make me think humidity because we have had the most horridness humidity here for the last few weeks when it started and it is very intermittent which again is making me think the air is making a difference. Just hard to believe they are so sensitive.
Old Mar 23, 2015 | 10:14 AM
The new fluid should be the correct fluid as prescribed by Mercedes/Chrysler. The wrong fluid can cause problems they say.
Old Mar 23, 2015 | 05:37 PM
Bay Cruise's Avatar
Yep, he is a Auto Box mechanic and does a lot of hot rods and said he filled with Merc oil so hopefully it is correct. Out late last night and early this morning with no humidity and car ran perfectly. Thinking more and more that he may be right.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
blackpepper
Oct 4, 2017 06:09 AM
brandoni
Sep 30, 2015 07:48 PM
BEATv1
Sep 10, 2015 12:58 PM
