automatic transmission
Old Apr 9, 2015 | 01:05 AM
grschulte's Avatar
Default automatic transmission
Hi. I just bought a 2005 Crossfire Coupe Limited. I took it to a Chrysler dealer to check everything out. The car has 42K miles, but the service rep said even though the book says change the automatic trans fluid at 80k, it should be changed because the vehicle is 10 yrs old. So they changed the fluid. A couple days later when I parked the car outside the charge I noticed an oily stain on the garage floor. Looking under the car I also saw what I thought was a frayed wire sort of hanging down from the bottom of the engine. I took it back to the dealer. They said the trans had burped and sent fluid out the overflow, but that no damage was done and I was good to go. In looking under the car again, I saw what looks to be a brand new silver mesh type hose. I now believe that the trans is a closed system. I don't know if a trans needs to be bled or not, but I think there was air in the system and that it blew out that mesh hose. I don't know how much fluid would have gone out if that was the case and if it is likely that the damage was done to the trans. I am not too mechanically inclined so if there is someone who can advise me as to what they think happened and if it is likely damage was done, I would be much appreciative. thanks. glen
Old Apr 9, 2015 | 11:04 AM
Default Re: automatic transmission
The 'mesh' hose is just a solid hose and nothing will come out of it unless it is damaged. But I'm not sure which one you mean, sorry.
There are two areas where oil commonly leaks from;
1, Is the yellow connector, it has a wire coming from it and it is toward the rear of the transmission on the passenger side.
The O-rings fail and leak, the oil travels all over the are behind the connector. Click
2, Oil can leak from the oil sensor area and can travel along the car toward the rear.
I'll add some pictures for you to look at.
syfi
Mar 28, 2026 04:14 PM
Oct 1, 2015 01:42 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
rfourt
Sep 25, 2015 01:38 PM
atdavis2
Sep 21, 2015 01:25 PM
