Let's discuss the key fob transponder chip(s)
Old Jan 13, 2019 | 03:14 AM
  #101 (permalink)
Padgett's Avatar
Default Re: Let's discuss the key fob transponder chip(s)
OK to really spell it out - the first photo (7930) is what the device read from the original working key. The late photos (7935) are from the new transponder. I have ordered some 7930s to see if that was the problem.
Old Jan 13, 2019 | 09:22 AM
  #102 (permalink)
You did spell it out originally, Graphite Ghost and I saw the different numbers. Maybe CL770 has different chips in his MBenz, I think I saw different chips for MB called up on the eBay listings.
Are there any numbers on the original chip?
Old Jan 22, 2019 | 01:40 PM
  #103 (permalink)
maggy55's Avatar
Hi, found this page, hope it helps
Zed-BULL Transponder Copy Applications | ?stanbul Elektronik Anahtar
Old Jan 22, 2019 | 08:24 PM
  #104 (permalink)
Padgett's Avatar
OK so I ordered 7930s. They sent 7931 "replacements". Didn't work. Am trying to get some real 7930s.
ps from the application list:33 RollingRollingNo
Old Jan 23, 2019 | 09:12 AM
  #105 (permalink)
I saw the type 33 Rolling code on the Maggie55 post and it makes me wonder if that will prohibit the cloning of our keys.
The plain type 33 seems to use the latest chip you have, xxx31.
Old Jan 23, 2019 | 03:31 PM
  #106 (permalink)
maggy55's Avatar
Hi, I read my key transponder before and after starting the vehicle and the code remained the same. It doesn't appear the the code gets rewritten by the screem.
Old Jan 23, 2019 | 04:58 PM
  #107 (permalink)
Centaurv's Avatar
I found sometime ago the Following on this site. I can't remember where but here it is :Trucs pour CrossfireThis is straight from the Crossfire manuals supplied to the dealership, or if you are a Chrysler tech, I got it from Tech Connect.
STANDARD PROCEDURE - TRANSMITTER PROGRAMMING
The Remote Keyless Entry Transmitter(s) can be programmed by the customer without special tools.
PROGRAMMING PROCEDURE
Transmitter programming by the customer is done by performing the following steps:
  1. Insert the key into the ignition switch.
  2. Press either the lock or unlock button momentarily twice.
Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Hope this is useful and saves you $100 or more.
Old Jan 24, 2019 | 12:26 AM
  #108 (permalink)
JSK's Avatar
JSK
That procedure is for lock unlock function not starting.
Old Jan 27, 2019 | 07:29 PM
  #109 (permalink)
maggy55's Avatar
I'll be trying to program some T5, PCF7931 and PCF7935 chips. I'll let you guys know how it works out.
Old Jan 28, 2019 | 01:31 AM
  #110 (permalink)
xodus52's Avatar
Thanks for your work on this CL770, Padgett, and maggy55. If you guys find a working and replicable solution for cloning the transponders, it would be immensely beneficial to the community.
Old Jan 29, 2019 | 04:11 PM
  #111 (permalink)
maggy55's Avatar
HI, got the PCF7935AS transponder chips today. . Used the Zed-Bull option 2 (copy transponder) . Put my key in , hit enter, hit read , it read the code, then placed transponder chip in read pocket narrow end down like it would be in key fob, hit write. Said it was successful. Turned the machine off and read code on chip a couple of more times, code still matched orig. key code. I still have to test this in the car, but so far so good. Will let you know. The key type says blank, but the code is right ?
Old Jan 29, 2019 | 04:20 PM
  #112 (permalink)
RED DOG's Avatar
WOW! That sounds VERY encouraging! . . . B R A V O !
Old Jan 29, 2019 | 08:52 PM
  #113 (permalink)
gragonese's Avatar
I will share my experience with cloning the chip. I purchased the Xhorse VVDI key tool having the same idea of cloning the chip from my existing key. I was able to read the data from the original chip and program that data into the virgin chip. I then scanned it again to verify the code took which it did. The key with the cloned chip would not start the car no many how many chips i wrote the code too. I gave up at that point as I had other things that took priority. Unfortunately I haven't had much time to resume troubleshooting but I definetly check this thread and help anywhere i can.
Old Jan 29, 2019 | 09:27 PM
  #114 (permalink)
maggy55's Avatar
The cloned chip would not start the car. I will try the other chips when they arrive.
Old Jan 29, 2019 | 09:32 PM
  #115 (permalink)
gragonese's Avatar
What was the model number of the chip you wrote to?
Old Jan 29, 2019 | 09:42 PM
  #116 (permalink)
maggy55's Avatar
Transponder Chip PCF7935AA Chip ID44
Old Jan 29, 2019 | 10:46 PM
  #117 (permalink)
Padgett's Avatar
Copied correctly but failed to work was my experience with 7935 and 7931s (ordered 7930s and got 7931). Complained and they are sending 7930s (when they get some). Like yours the 7935 reported blank but the 7931 matched except for the -31 instead of -30. That is the last variable. Not that after about two weeks and a number of starts the data did not change.
Old Jan 30, 2019 | 12:07 AM
  #118 (permalink)
Did you expect changes? If so why.
I think the door locking code changes at random not the info on the key chip.
Old Jan 30, 2019 | 11:19 AM
  #119 (permalink)
KDW4Him's Avatar
Door locking code changes? That would be the rolling code lock/unlock remote function. These guys are cloning RFID chips to get the SKREEM to allow the cloned chip to start the car. Two separate functions.
Old Jan 30, 2019 | 12:09 PM
  #120 (permalink)
I say exactly that, you misread my post.
I use the word NOT.
