Nothing but trouble - Sticky Key and Power Windows
Old Apr 8, 2019 | 08:52 PM
cheetah500's Avatar
Default Nothing but trouble - Sticky Key and Power Windows
I am a new owner 2005 coupe black in and outside. 60,000 miles. ..owner admitted to 1 problem window only works for a minute if you pull the fuse and put it back in will work again ..but only 1 or 2 times...not a deal breaker for me.. car was running....he met ne somewhere..took for test drive..mabe shut it off but left key in. $47,000 Driving home stopped for the bathroom ...key locked up..30 minutes later she starts...not a good start..
Old Apr 8, 2019 | 09:09 PM
Default Re: Nothing but trouble
Common problem, once completed, you won't have this trouble again. check here:https://www.crossfireforum.org/forum...key_fix_v5.pdf
https://www.crossfireforum.org/forum...y-success.html
Old Apr 8, 2019 | 10:09 PM
cheetah500's Avatar
Yes I did see the sticky key fix. was reluctant at first, but took out switch housing and removed cam pin and spring, did not remove tumblers, everything good. Thanks to all...on to the next problem... drivers window only works a time or 2 after you pull the fuse and replace it.same fuse it is not blown... switch has been replaced, motor must work... a relay?
Old Apr 10, 2019 | 01:12 PM
Change the seat relay, $29. Part is, oddly enough, easy to find and easy to change.
There are probably five threads here on it.
Or take it to a dealer and spend $400 to $600 for them to "diagnose" it.
*Moved to appropriate forum*
Old Apr 10, 2019 | 01:33 PM
cheetah500's Avatar
Default Re: Nothing but trouble - Sticky Key and Power Windows
With no power seats bo heated seats do I have a relay to change?
Old Apr 10, 2019 | 02:44 PM
Limited and SRTs have leather powered, heated seats. Those have a seat relay.
Base and SE models have cloth manual, unheated seats. Those have no seat relay.
onehundred80
Apr 16, 2025 04:43 PM
Deaf Eddie
Mar 8, 2021 09:56 AM
grip grip
Mar 29, 2020 02:05 PM
rom173
Jun 21, 2014 02:36 PM
Reichsrundfunk
Feb 10, 2014 07:15 PM
