Automatic Transmission Ticking
Old Jun 4, 2019 | 07:15 PM
grossmj's Avatar
Default Automatic Transmission Ticking
A few months ago my 2004 crossfire had a problem at the tail of the dragon and it had to be towed home on a tow dolly (4 hours home). I got the original problem fixed; however, when I got in the car to drive it, the car struggled to move when in drive or reverse. I also noticed the car had developed a constant ticking coming from the transmission ONLY when in drive or reverse. I looked on the forum and it seems no one has posted about this problem before. I have tried different RCMs and checked the transmission fluid level, but no progress. Does anyone have any ideas what can be causing this?
Here are two videos I took of the ticking
Old Jun 4, 2019 | 08:08 PM
Default Re: Automatic Transmission Ticking
I certainly hope you had it towed on a flatbed.
If you had it towed with just the rear wheels on the ground, did you remove the driveshaft ?
If not, then you have probably destroyed every bushing/bearing in the transmission.
DGDanieljr1
May 10, 2011 08:05 PM
Karl Von
Apr 7, 2008 09:47 PM
VQ35DE
May 27, 2006 10:02 AM
crossfirechick
May 13, 2005 11:27 AM
pageoneresults
Mar 23, 2004 06:53 PM
