Relay Command Module
Old Jun 22, 2019 | 10:23 PM
crossfire121's Avatar
Default Relay Command Module
Hello ,
Is it possible to buy the individual relays for the RCM as my fuel pump relay is dead ?
I am in the UK, Thanks
Old Jun 22, 2019 | 10:31 PM
Default Re: Relay Command Module
Originally Posted by crossfire121
Hello ,
Here is a PDF with the relay part number in it, there are other makers of the relay naturally as the relay is a standard part. CLICK
Old Jun 22, 2019 | 11:43 PM
Many thanks for the part number , would you know where best to purchase these relays from within the UK ??
Thanks again
Old Jun 23, 2019 | 12:01 AM
Hello , Do you know what the relay coil resistance is please for the fuel pump relay. As 2 of the relays are 36 ohms and another 2 are 70 ohms on the RCM
Thanks again
Old Jun 23, 2019 | 03:36 AM
All 4 relays are identical. To get a true reading the relay has to be removed from the board.
The coil resistance according to the spec sheet for relay
American Zettler
AZ970E-1A-12D
is 90 ohms.
https://www.crossfireforum.org/forum...cement-rcm.pdf
Old Jun 23, 2019 | 09:24 AM
American Zettler
AZ970E-1A-12D
is 90 ohms.
I see my Data Sheet in the PDF is not working and the picture in the main PDF is an obsolete one. Guess that will have to be fixed.🙄
mcjack301
Oct 1, 2020 05:55 PM
pjs626
Apr 3, 2017 06:49 PM
Style
Jan 21, 2015 10:38 PM
tighed1
Nov 20, 2009 11:02 AM
Louie K
Aug 11, 2007 08:25 AM
