ABS system and break bleeding
Old Jul 14, 2019 | 09:04 AM
Default ABS system and brake bleeding
If we want to bleed the ABS module we need a dealer who can do it. What we need is a smart guy who can solve the problem.
Surely to make the solenoids in the ABS work we just need to apply some electrical pulse to them? Take of the plug and apply the current to the correct terminals Would that work?
Most say bleed the longest brake line first, is that really true any more? Each of the four lines originate at the ABS pump there is no tee in the front or rear systems like the old days, each brake has its own circuit.
Changing the master cylinder carries the risk of getting air into the ABS pump.
Ideas?
Old Jul 14, 2019 | 09:10 AM
Default Re: ABS system and break bleeding
Gimme a BRAKE !!
Can't believe your thread is titled :
Old Jul 14, 2019 | 09:15 AM
zip439's Avatar
Take a look at the Launch Millennium 90 Pro. Next credit card period I hope to squeeze it in. Say it will bleed brakes.
Old Jul 14, 2019 | 10:34 AM
Gimme a BRAKE !!
I am getting sloppy, sorry. I spelt it correct elsewhere.
I added the word break at the last minute.
So any ideas?
Old Jul 14, 2019 | 10:36 AM
You need to see ‘bi-directional’ in the specs, also some work only on some models as I have found out. One of my readers says it does it but it does not. I complained to the maker and got no answer.
Old Jul 14, 2019 | 11:19 AM
Spelt?
Old Jul 14, 2019 | 11:56 AM
Spelt?
https://www.dictionary.com/browse/spelt
Old Jul 14, 2019 | 12:10 PM
Spelt?
I guess it is where you come from. My Canadian English spell checker corrects the word spelled to spelt. We developed the language and you guys just messed it up.
Looking at what passes on this forum as English I do not do too bad, I do not use spelling based on the sound of the local accent.
Spelled vs. spelt
In American English, spelt primarily refers to the hardy wheat grown mostly in Europe, and the verb spell makes
spelled in the past tense and as a past participle. In all other main varieties of English, spelt and spelled both work as the past tense and past participle of spell, at least where spell means to form words letter by letter or (with out) to make clear. Outside the U.S., the two forms are interchangeable in these uses, and both are common.
No comments on the post except digs. What about some sensible remarks.
Old Jul 14, 2019 | 12:34 PM
So any ideas?
No, still watching to see if anyone has an answer to this ABS bleeding other than wet grass, and who knows, maybe that IS the answer.
Old Jul 14, 2019 | 01:15 PM
That seems to work but I think that if you could do it with the car stationary and the bleeders open you could get the air into the lines easier. The way I read the workings of the ABS pump the ABS motor builds up the pressure after the solenoids have released the pressure. Maybe we need to open each solenoid in turn and get the motor running thus expelling air from the motor into an open line.
The grass method may work but some air may just go back to where it came from.
Old Jul 14, 2019 | 03:20 PM
UrbanE's Avatar
Wow
180, you’re constantly providing assistance. Everyday you point a forum members to correct threads and provide backup docs and links for most topics.
You (180) ask for assistance, in that ask you inadvertently spell a word, correctly, one that sounds the same but has a different meaning (I believe it’s called a homonym) and you’re called out for an error. It’s a forum about cars, I think we all know the intent break vs brake. Let’s rise above being petty.
ladies and gentlemen in the country South of ours, we try to do things differently in Canada, Like take the high road.
Here are a few more for you. English in its original form. I know it will blow your minds
labour
neighbour
cheque
There is enough pettiness out there, we’re a group with a common interest. Let’s stick to our common obsession and not look for ways to pounce on one another.
180, as a fellow Canuck and from all Canucks on the forum we stand on guard for thee
You rock
Old Jul 14, 2019 | 03:47 PM
UrbanE, what you don't seem to realize is that Dave and I have for years enjoyed catching the other in a faux-pas.
I was NOT being petty, I was merely adding a check mark to my side of the ledger
Old Jul 14, 2019 | 05:56 PM
UrbanE's Avatar
Ahhhh
my bad
you know the saying
“no one can hit my brother except me”
carry on
Old Jul 14, 2019 | 06:12 PM
Originally Posted by UrbanE
Ahhhh
my bad
you know the saying
carry on
No problem.
Your avatar is cleared to land runway 18, exit right taxiway Baker, contact ground 121.5.
Old Jul 14, 2019 | 08:11 PM
velociabstract's Avatar
About braking on wet grass, you have to re-bleed afterwards to remove any air that was expelled from the ABS module. Just in case this was in doubt.
Les
Old Jul 14, 2019 | 11:53 PM
Les
That is what I understand, bleed first then slide around the local soccer pitch. Race home to avoid the police and bleed again. Repeat as necessary until the brakes are nice and firm or the cops catch you.
Old Jul 15, 2019 | 01:28 AM
WD40's Avatar
Can always go back to using mechanical brakes. As salesmen of behind-the-times-cars said in the 1920s, "Do you really trust a LIQUID to do your braking?"
Heck, on a 1973 MG Midget I owned the master-cylinder was not yet divided internally into two sections. I had to replace it once and when it gave out you really noticed!
Old Jul 16, 2019 | 08:07 AM
zip439's Avatar
I had a midget in the late '60s: I'd be changing out the clutch every 12 months and seems I could find every thunderstorm in the state by simply letting the top down. Hence I drive a Crossfire coupe.
Old Aug 28, 2019 | 01:24 PM
This is a question for the electronic geniuses we have on the forum.
When the ABS is used what kind of signal does the unit get from the sensors? I was thinking of buying a spare ABS unit and seeing if I could trigger it to actuate the solenoids inside it so they pumped out the air in the ABS unit on the car. The connector to the ABS unit has a lot of pins on it and finding the correct pins may be a bit of a headache.
Obviously, the idea is to replicate the dealers DRBIII units function to bleed the ABS module.
Can it be done?
Old Aug 29, 2019 | 06:06 PM
I guess we have nobody who can answer this question, plenty of people who can spell though.
I give up.
