convertible top help
Old Jul 26, 2019 | 08:16 AM
loudrango's Avatar
Default convertible top help
Hi all.I've searched the forums for an answer,but i didn't see a solution to my exact problem.it's a 2005.unlatch the windshield lock,windows go down,latch under the window comes up 3/4 of an inch and stops.my other problem is that all of a sudden the trunk doesn't open.(it has a new actuator pump)so i can't even get in to check divider,etc.after work i will try an access through the tag light.tia for any help.
Old Jul 26, 2019 | 08:44 AM
loudrango's Avatar
Default Re: convertible top help
forgot to add...top pump is working.
Old Jul 27, 2019 | 10:36 AM
loudrango's Avatar
update...i'm having the same exact issues as old dawg posted above me except my top is up and my spoiler is up.went out to check to see if my spoiler worked...didn't go down.my fuses are good,no esp light on,and my battery is two weeks old....any more thoughts?thanks for any help.
Old Jul 28, 2019 | 01:36 PM
I don't know what that means. Latch under what window?
Do you mean the BOW? That is, the rear bow, that latches into the lid when the top is up fully?
If so, if the bow only goes up a little, you most likely have low fluid in the system due to a leak OR a sensor somewhere that is not reporting travel properly.
What "actuator pump" do you refer to?
If the top cycle does not complete, (and yours obviously hasnt) then the electric trunk lock is locked because the TCM only unlocks the trunk at the END of the cycle - so this is expected behavior.
Old Jul 28, 2019 | 01:37 PM
Sounds like what you MEAN is: "I can hear the pump running, so it must be working.
That is not always the case.
Old Jul 28, 2019 | 01:39 PM
Are you trying to put the top up and down with the engine NOT running?
If the wing won't respond AND you are having top issues, I'd think "low voltage" due to the alternator not charging and/or a weak battery. Of course, if the engine is not running, then you WILL have low voltage.
Old Jul 28, 2019 | 01:46 PM
From your PM (I am answering in public in order to help others who will read this AND to keep all the correspondence in the same thread):
the other day top worked fine.go out yesterday unlatch the d ring lock on the tonneau cover came up about 3/4 of an inch and stopped working.
also with this spoiler stopped working along with the trunk.got in the trunk through the tag light and fluid was empty.found the leak and fixed it..
I've never heard of a leak so bad the tank was EMPTY. How long have you owned the car?
when i first tried to open it after the d ring was unlatched the windows didn't go down until i hit the top switch.so the sequence is unlock d ring,windows don't go down,get the beeping and the top light blinks.
The idea that the windows did not go down when you turned the "D" ring means the switch up there is bad, the top control module is bad, or the BCM and TCM are having a hard time "talking".
I will get back to this in my last response in this post.
the vacuum actuator for locks is new,
What EXACTLY do you refer to? Then entire lock pump assembly? And why was it replaced? (I suspect this is all related).
battery is 3 weeks old,fuses are good,and if i start the car the trunk will once again not open unless i get in through the tag light.other than bcm any other ideas i can try at home?thanks for any help you can provide.
There is too much going on here to make sense of it all. SO: Rip out the trim from the ENTIRE TRUNK. Look for ANY signs of water intrusion ANYWHERE in the trunk or wheel wells. If you find any, the road to fixing this may be quite involved. If no water damage is found, just knowing that is worth yanking the trim out.
One more time: What is your history with the car? Bought it last week? Owned it ten years? Stored it three years while you traveled to Mars for the CIA?
Old Jul 28, 2019 | 02:59 PM
loudrango's Avatar
thanks for the replies pizzaguy.i've had the car two years.trying the top with car running always,vacuum actuator for locks is new.
Old Jul 28, 2019 | 03:00 PM
loudrango's Avatar
thanks for the replies pizzaguy.i've had the car two years.trying the top with car running always,vacuum actuator for locks is new.and you can hear the pump trying to work.i will disassemble the trim and check for any water.thanks again.i appreciate it.
rcompart
Mar 21, 2024 09:42 AM
wbaker1970
Jul 4, 2009 10:56 AM
gr8len
Apr 2, 2007 01:21 PM
xrtime
May 28, 2006 05:34 PM
