Clicking no start / good battery
Old Jan 3, 2023 | 07:04 PM
svtmerc's Avatar
Default
I thought I had it fixed, but it had me stranded in a parking lot, i disconnected the battery, reconnected it and it started right up, i drove back, parked it, had to move it, and it was fine, went to leave. and nothing but click, click, click... I'm pulling my hair out on this car
Old Jan 14, 2023 | 02:50 PM
svtmerc's Avatar
Default Re: Clicking no start / good battery
need advice on this please
Old Jan 14, 2023 | 03:07 PM
Two things come to mind, a bad battery or a bad battery connection, probably the negative but check the terminals for corrosion or looseness.
Old Jan 14, 2023 | 07:28 PM
svtmerc's Avatar
Got it....
It was the positive cable.
I had already cleaned the cable ends and terminals the last time it happened and everything worked fine for 2 weeks, until today. I tested the battery voltage and the voltage at the distribution block and had 12.7 volts in both spots. Still, I took it to O'rileys and it did test good. So I decided to check the cable ends again amd noticed the positive end had been replaced and the wires weren't corroded, but dirty and and a little greasy. So a bit of disassembly, cleaning, and reassembling, and she fired right up.
Old Jan 14, 2023 | 07:39 PM
That car is headed for BIG trouble, if I read your post #4 correctly. If you have one of those HORRIBLE battery cable clamps that you can take apart, you are headed for trouble.
I'd replace it with a cable that is welded (like the OEM cables). With the connection that poor, on those times you did get the car to start, the battery's connection was resistive and therefore your battery's ability to filter the crud and crap from the starter, alternator and any heavy motor in the car is impaired. The spikes that those motors can generate can be substantially higher than 14 volts, putting various modules at risk.
I have been involved in automotive accessory electronics since 1983. But it's your car, so do as you please. Just sayin.
Old Jan 14, 2023 | 08:24 PM
svtmerc's Avatar
Trust me, I am NOT a fan of shitty aftermarket crap. I have other items on the agenda for her that take precedence, primarily compmete fuel system overhaul, plugs and wires, and a couple other odds and ends, but I will be making a new, higher quality cable for her.
Old Jan 14, 2023 | 10:05 PM
I saw a compatible welded replacement cable online a few days ago. $55 but I think it's worth it. It was not OEM (it was #2 cable and 58 inches long, factory was #4 and like 42 inches).
I was thinking of ordering one for mine for use "some day" but then didn't.
deltacrossfirebob
33
Sep 21, 2018 07:35 PM
knoxxxy
23
Mar 22, 2017 08:21 PM
gronda
20
Jul 29, 2015 03:07 PM
ri2300
Nov 22, 2010 05:48 AM
KROSSFIRE1988
38
May 4, 2010 04:54 PM
